MiRGE Radio and FM Transmitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-18-2009, 09:53 AM - Thread Starter
EclipseGSX's Avatar
I just got a Sirius/XM MiRGE radio to replace my worn out Sportster Replay 2. My old radio had an absolutely kick-ass FM transmitter... I could tune it in from 200+ feet away, with obstacles. Now I notice that the MiRGE has the option to turn on the FM transmitter, but upon doing that I got nothing coming through on my stereo, even from a foot away.
Unlike the Sportster, the MiRGE doesn't have an antenna port to plug in the FM antenna -- only line-out. The manual states that the FM transmitter is for use with XM SureConnect or XM FM Direct adapters; both of which are geared toward automobile use. Is there something I can attach to take advantage of the FM transmitter at home? I only need about a 40-50' range.
Any suggestions would be greatly appreciated.
EclipseGSX is offline
post #2 of 4 Old 09-18-2009, 12:57 PM
barbie845's Avatar
Because of a FCC ruling the internal built in FM transmitters in all new XM and Sirius equipment suck.. So you do need an external FM transmitter.
I've used this LineX transmitter for many years. It has about 1/2 city block range and it is inexpensive..It plugs into the headphone jack.
The only drawback is it runs on batteries, but I use rechargeables in it so if I forget to turn it off and the batteries drain down it's no big deal..
http://unlimitedcellular.com/p-5497-...ansmitter.aspx
Edit...There is a seller on Ebay who is selling them for $19.99...So if you have an Ebay account that might be the easier way to go.. Search>>>> LineX FM
barbie845 is offline
post #3 of 4 Old 09-18-2009, 01:18 PM - Thread Starter
EclipseGSX's Avatar
Thank you for the information -- I guess I'll have to go the external FM transmitter route. It's too bad that the LineX doesn't support external power adapters (AC or DC).
I found the C.Crane linked from another review here on the forum, and it comes with an adapter. Of course, it's much more expensive (~$70).
Has anyone here successfully rigged a LineX to use external power?
Damn you, FCC!
post #4 of 4 Old 09-18-2009, 01:28 PM
barbie845's Avatar
Damn you, FCC!
Yes, both here and on other sites I have seen the Crane transmitter recommended very highly. The only draw-back is the cost. This LineX is a much cheaper option, AND it has very, very good range.
I never even tried to rig it up with external power because like I said I use 3 AA rechargeables. And the battery life in it is pretty good. Even when using rechargeables.
Reply XM and Sirius Satellite Radio
