Sirius cutting out - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By andyross63
post #1 of 11 Old 08-18-2010, 02:31 PM - Thread Starter
willie42's Avatar
My Sirius service, factory installed radio in my Mercedes SUV, repeatedly cuts out -- in town and on the interstate. This may be momentary or bring "acquiring signal" message. The dealer has replaced the antenna, and both dealer and Mercedes customer service state this is inherent in the Sirius service. I live in FL, so no problem seeing the satellites. They don't get a fault indication when testing the radio, so have not yet replaced it. Is this common, and does anyone have any suggestions?
willie42 is offline
post #2 of 11 Old 08-18-2010, 02:45 PM
ccotenj's Avatar
Liked: 101
they are blowing smoke up your behind...
the only times i get dropouts from sirius in my car is when i'm blocked from the signal (bridge overpass, heavily wooded area, etc.)...
i never get dropouts at home...
keep pushing... something isn't right....
- chris
ccotenj is offline
post #3 of 11 Old 08-24-2010, 05:54 AM
johnndeanna's Avatar
The only time mines cuts out is under cover, and it has to be significant cover such as an overpass. Even in heavy tree cover I seldom lose it. Although on the Disney Channel 115 (little girl in the house) I do get intermittent pauses but only on that channel. Otherwise my Stiletto has proven wonderful and love having it. Can you say 80s on 8?
John Martin
johnndeanna is offline
post #4 of 11 Old 08-25-2010, 05:56 AM
tveli's Avatar
Quoted: 28 Post(s)
if swapping the antenna didn't fix it, it could be the satellite receiver unit itself, or the wire leading to the antenna.
btw, when I drive in florida I notice that when next to big-rig the signal could cut out rarely/briefly.
a possible way to prove there is problem with vehicle sat system is to use another receiver, and position the other receiver's antenna next to the benz sat antenna. you can do this with a single subscription because the signal problem will be evident even on channel 184, the no-subscription channel.
also you may be able to demonstrate this in the benz dealer's parking lot. drive around until you find a spot where the problem happens. then drive another benz from the lot next to your car. crank both radios, and point out to service tech when your radio goes off and the other does this. swap the cars positions, and then demonstrate the issue again, to prove that a 10 foot offset in position is not the cause.
tveli is online now
post #5 of 11 Old 01-30-2015, 01:31 PM
Liked: 0
I originally installed an after-market Alpine Nav system with SiriusXM in my Honda C-RV. The installer put the XM antenna on top of the car and the XM tuner module in my top glove box, away from the Alpine unit and other electronics. It worked fine for many years.
I replaced this unit, after some trial-and-error, ultimately with a Pioneer AVIC Nav System with SiriusXM. The installer put the XM antenna inside the car on top of the dashboard and the tuner was placed in the space behind the Pioneer AVIC system. I had the same problems with the SiriusXM cutting out that many other people are describing. On long trips (the main reason for paying for XM in the first place) it would cut out completely. I tried refreshing from SiriusXM and this did nothing to solve the problem. We also tried moving the XM antenna to the ceiling above the driver side visor, but this did nothing to solve the problem either - it may have even made it worse.
So I had the installer install it just as my Apline's SiriusXM had been installed: XM antenna on roof behind windshield; XM tuner in top glove box. (See pictures.) This fixed the problem.
Theory: It is possible that only one of these steps was necessary, but I'm not sure which. It is possible that the XM antenna needed to be higher up and away from other electrical interference inside the car. It is possible that heat or electrical interference from other devices were causing problems with the XM tuner and isolating it in the glove box prevented this. Both may be true, but I know that doing both of these things definitely fixed the problem in my case.
Please try this solution and let us know how it works.
Paula Newman is offline
post #6 of 11 Old 02-26-2015, 09:36 PM
lockuplever's Avatar
I've had several cars cut out all over town for the last 6 or 7 years. It always happens at the same intersections, it has to be something disrupting the signals in those areas.
lockuplever is offline
post #7 of 11 Old 08-24-2015, 09:05 AM
finnface's Avatar
I live in SF bay Area.
I'm in a car pool with 3 of us with Sirius in our cars.
The signal drops off when ever we pass the big cell phone towers. Anywhere from 1 sec to 10 secs. always at the same spots like just driving down 101, or by the airport, ext.
Ive had Sirius in my car since 2008, and now its so bad I'm ready to drop it from my car.
I can deal with moments of no signal from the overpass's but in the open..not right.
I'm surprised there are not more complainants.
finnface is offline
post #8 of 11 Old 08-24-2015, 03:14 PM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
They may be using microwave links that are near Sirius's frequencies and end up overloading your tuner. Satellite signals are VERY weak and it doesn't take much nearby noise to kill them.
It's similar to your car remote to not work well if at all if you are near an FM transmitter.
pilotart likes this.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #9 of 11 Old 08-26-2015, 07:40 AM
Brad Bishop's Avatar
Quoted: 13 Post(s)
Isn't the Sirius side operating one 2 (instead of 3) polar satellites and 1 geostationary satellite now with no terrestrial repeaters?
When it was 3 polar satellites it was pretty excellent. Before I pulled Sirius from my car (and replaced it with SiriusXM (XM side) radios) it'd take a few minutes just to acquire the signal which was a lot different than just a few years ago.
What sucks is that, in my opinion, the polar satellites were the way to go for mobile listening. Geostationary is better if you're going to attach an antenna to your home. They seem to be going Geostationary, XM-side only for terrestrial repeaters. The Sirius side is treated more along the lines of, "do the bare minimum.. because we have to.."
Brad Bishop is offline
post #10 of 11 Old 09-12-2015, 08:10 PM
Liked: 0
Do car factory radios just use terrestrial (I think that's what it was called)? Both our car factory radios drop out often but neither has the setting I remember having when we had a portable radio being in the car, which I believe was Satellite and Terrestrial.
mbraun61 is offline
post #11 of 11 Old 09-12-2015, 10:13 PM
STEELERSRULE's Avatar
Quoted: 60 Post(s)
Liked: 25
They use both. Whichever is available. All the antenna's receive both satellite and terrestrial in cars, portables, etc...
STEELERSRULE is offline
Reply XM and Sirius Satellite Radio
