Streaming vs Home Tuner - AVS Forum | Home Theater Discussions And Reviews
Old 12-29-2011, 01:54 PM - Thread Starter
Azvipers's Avatar
I am about to replace my home theater receiver that has a Sirius over the air home tuner connected. I am replacing the receiver with an Integra receiver that streams Sirius from the internet. My question is if the sound quality will be the same via internet or would I be better buying a separate home tuner and using an antenna?
Azvipers is offline
Old 12-29-2011, 02:35 PM
I WANT MORE's Avatar
Quoted: 410 Post(s)
Liked: 270
IMO over the INTERNET has better sound quality but Sirius does not offer the full lineup of programming via streaming.
Perhaps I misremembered.
I WANT MORE is offline
Old 01-04-2012, 11:53 AM
Brad Bishop's Avatar
Quoted: 13 Post(s)
I'd say it wins both on:
- It'll be easier to hook it up since Echo Repeaters are no longer available
- It'll be higher quality audio since they compress the satellite streams so much.
Brad Bishop is offline
Old 01-07-2012, 01:32 PM
Savageone79's Avatar
Internet stream is significantly better but as stated you loose some channels.
Savageone79 is offline
Old 01-08-2012, 12:59 PM
oth
oth's Avatar
XRadio/Sirus
Satellite Feed
High-Efficiency Advanced Audio Coding (HE-AAC)
32 kbps -- 64 kbps channel and load dependant
Internet Feed
128 kpbs wma
Pandora One (paid)
192 kpbs mp2
I dumped my old xm adapter and went with internet feed on my AV receiver. Saved some money as well.
enjoy...
oth is offline
