Do You Record SiriusXM? If So How? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 03-30-2013, 10:09 PM - Thread Starter
njemelbourne's Avatar
Right up until recently I was recording Howard 100 using Pulsar and Audio Hijack but they are discontinuing Pulsar as Sirius XM are trying to kill 3rd part apps that stream their channels (yes, you have to be a subscriber to do so).
I record the show for listening later due to my unusual work hours (I'm asleep when the show airs).
Does anyone else record the show (mac user here)?
What applications do you use?
I have told my wife that when I die I wish to be buried in a steel book. A large one albeit, but yes, a steel book.
njemelbourne is offline
post #2 of 29 Old 03-31-2013, 03:21 AM
Joel Graffman's Avatar
Pulsar was nice, too bad we can't use it any more.
I still occasionally use Audio Hijack for recording XM, I keep an output of my Delphi receiver plugged into my Mac Mini. Works fine, of course you must leave the receiver turned on.
Mastermoto
Joel Graffman is offline
post #3 of 29 Old 03-31-2013, 06:55 AM
RCbridge's Avatar
Quoted: 16 Post(s)
I on occassion will record music and save it to my PC or just record to a CD.
RCbridge is offline
post #4 of 29 Old 03-31-2013, 07:00 AM
Brad Bishop's Avatar
Quoted: 13 Post(s)
I use an Antex XM100 receiver as the source. It allows you to setup timers so that the station will change for various programs.
I then use Audio HiJack Pro to do the recording and dump it into a directory.
There's a python script I found a few years back to actually generate the RSS feed and then I use Apache to serve it to iTunes and have some other scripts setup so that it just refreshes when needed and right away, meaning, 1 min after the recording has ended it builds the RSS feed and hits up iTunes to refresh that particular feed.
It works quite well.
I would think that you'd be able to start the XM Online streamer and set the channel with the right parameters, and then use Audio HiJack Pro to record from Safari, or Chrome, or whatever it is you like to use, but I have never tried it.
Brad Bishop is offline
post #5 of 29 Old 04-29-2013, 03:39 PM
Michael P 2341's Avatar
Quoted: 230 Post(s)
I get the Sirius music channels via Dish Network. I have recorded "Breakfast with The Beatles" off Underground Garage on my Dish DVR.
Michael P 2341 is offline
post #6 of 29 Old 05-05-2013, 03:51 PM
STEELERSRULE's Avatar
Quoted: 66 Post(s)
My God, why make this so complicated.
Just go on EBay and Buy either a Stiletto 100, or a Stiletto 2. With BOTH the car dock, and home dock, it will probably run you around $180 for everything. Probably a little less for the Stiletto 100 since it is a little older.
I do the same thing you do. I let my Stiletto 100 record the show, then I listen too it at my leisure. I also FF through all the commercials. And if Howard is interviewing, or doing something I could a give rats a** about, I simply FF/Skip through it all.
That is what I would do.
STEELERSRULE is offline
post #7 of 29 Old 05-07-2013, 11:56 PM
ChrisSwanson72's Avatar
OR, you could just do what I do,
I use a Sony Minidisc recorder, the JB940 unit.
I have recorded Eddie Trunks show on Hair Nation many times for
future listening.
However, be FOR WARNED: If buying an md MiniDisc unit off of Ebay
MOST sellers will lie, and
say the unit is in 100% perfect working condition, and
when you get it, it`s broke!
THERE ARE NOT ALOT OF REPAIR MAN THAT YOU CAN TAKE THESE TOO ANYMORE TO GET FIXED!
PARTS ARE NOT AVAILABLE, I RAN INTO THIS PROBLEM 3 TIMES IN 2010-2012.
IF you can find 1 off of Craigslist, so you can go and TEST it, BEFORE buying it!
The sound quality, is as good as listening to the radio itself, and it does NOT degrade!
ChrisSwanson72 is offline
post #8 of 29 Old 06-04-2013, 09:40 AM
s4mb4's Avatar
they do not make it easy anymore, that is for sure.
on windows, i use chrome to log into the sirius app.
i run a program called SiriusKA. (i think it is just mouse macro software)
once that is all going, any type of PC recording software will do the trick. I use Total Recorder Professional 7
not as easy as it was with Roque's software but it works.
s4mb4 is offline
post #9 of 29 Old 04-18-2014, 08:41 PM
grambo30's Avatar
Recording SirusXM Online
Once upon a time I used XM Tuner, then I used SiriusXMStreamer.
On 2014-04-17 SXMS stopper working.
After trying a bunch of stuff I hit on this decent solution for recording.
1. Start SiriusXM Online player
2. Choose the channel you want to listen to
Your address bar will look like this:
https://www.siriusxm.com/player/#view=channels
3. Now click Now Playing.
Your address bar will read something like this
https://www.siriusxm.com/player/#view=nowPlaying&channelId=siriuspatriot
4. Download and Start Replay Radio 9 ($29.95)
5. In RR9 Skip the Quick record nonsense and click Schedule Tab
6. Right Click and Select New to creat a show
7. Type a name (Example WM_{Y}-{M}-{D} The YMD adds date to the name
8. In the URL copy and paste URL from step 3 above.
9. Set Capture to Record Audio Output
10. Set Launch to In Tuner
11. Set Convert and Media Folder to your choice
12. Select Tuning Tab and add URL form Step
and set Player to Browser
13. Select Tags and set to your choice
14. Right Click on show and select Start Recording
grambo30 is offline
post #10 of 29 Old 08-05-2014, 07:44 AM
The Grim Reaper's Avatar
Anyone have a good idea on how to record certain Sirius NFL Radio programs to MP3? Radio Replay9 isn't good for that.
The Grim Reaper is offline
post #11 of 29 Old 02-26-2015, 08:28 PM
lockuplever's Avatar
10 year old XM PCR, still works great!
lockuplever is offline
post #12 of 29 Old 04-26-2015, 05:39 AM
YeoldMetalhead's Avatar
I use Audacity software to record the streams. It has a bit of a steep learning curve but it is easy to use once your familiar with it.
I set up the Audacity, log onto the Sirius player and hit record.
The sound quality is actually better (slightly) than listening directly from the Satellite. I get no compression artifacts.
I personally use it to record their On Demand shows so I can burn them to CD to play on my main stereo.
And it is Mac friendly.
http://web.audacityteam.org/
http://www.macupdate.com/app/mac/8052/audacity
YeoldMetalhead is offline
post #13 of 29 Old 05-27-2015, 08:24 PM
Liked: 0
Help
I downloaded Audacity. I downloaded the SiriusXM Player. How do I get the audio into the Audacity input? It wants to use the laptop microphone.
jeffmoskin is offline
post #14 of 29 Old 05-28-2015, 03:21 AM
If you look at the screenshot you will see just above the numbers 1 2 3 4 etc a few bars that show WASAPI and Speakers (Audioquest) etc. These you set for your particular soundcard and inputs.
If your still having problems go this page:
http://manual.audacityteam.org/o/
post #15 of 29 Old 05-28-2015, 06:34 AM
Liked: 0
Mine says "Core Audio Host" and I cannot change it. There must be a way.
Also, I cannot switch off the tool "Built-n Microphone"
post #16 of 29 Old 05-31-2015, 06:15 AM
Super Moderator
DrDon's Avatar
Quoted: 1323 Post(s)
Liked: 2566
If you're trying to record what you hear, you'll need a full-duplex sound card. If your laptop doesn't have that, then you can't do it. Head to the Control Panel > Hardware and Sound > Manage audio devices > Recording tab. Right click "show disabled devices" and "show disconnected devices." Checkmark both. If you don't see something like "stereo mix," then you have a half-duplex card. If you DO see "stereo mix" set it as your default, then go into your recording program and set the input accordingly. (I use Adobe Audition, so I'm only familiar with that).
I don't have SXM internet, so I just jack my SXM radio into the computer's line input, set Audition for delayed start and go on about my day. I've recorded about a dozen hours of Spa that way, edited out the spoken IDs and copied the file onto my phone to help me sleep on flights.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #17 of 29 Old 05-31-2015, 07:13 AM
Liked: 0
Bingo!
Thanks, DrDon.
Sure enough, my Mac Air has only a micropbone input.I have the SXM app on my iPhone. Perhaps I can get a 3.5mm male to male cord and use it as a source. I used to have a stand-alone receiver but no longer do. I too like SPA to fall asleep on long flights.
post #18 of 29 Old 05-31-2015, 07:20 AM
Super Moderator
DrDon's Avatar
Liked: 2566
You'll need a cord with a built-in pad. Line-level out to microphone in is going to distort like hell.
DrDon is online now
post #19 of 29 Old 05-31-2015, 07:52 AM
Liked: 0
Come to think of it, there is no input jack on this thing. It is an otherwise great laptop.
Oh, well.
post #20 of 29 Old 05-31-2015, 08:01 AM
Super Moderator
DrDon's Avatar
Liked: 2566
You'll need an external sound card, then. I don't work in the Mac world, but I've been carrying around a SoundBlaster USB device for some time. Used to do a lot of broadcasts from Nashville. I always had my laptop connected to the audio console so if the line back to the station dropped, I could continue doing the show and e-mailing the breaks back to the studio. Actually happened during a New York broadcast. Laborious, but listeners never knew there'd been an issue.
DrDon is online now
post #21 of 29 Old 05-31-2015, 06:23 PM
Liked: 0
Then I need a stand-alone SXM receiver to feed it which I don't have. I think I'll resurrect my old Dell XP laptop and use it.
Microsoft did some things better than Apple.
post #22 of 29 Old 07-02-2015, 01:52 AM
Liked: 0
I have searched a post on Google, it offered several ways, and I tried to record from sirius successfully with Apowersoft Free audio recorder. But it has been a long time ago, so I am not sure if the radio has made other limit to recorders. You can give it a try.
Twelve Edin is offline
post #23 of 29 Old 08-03-2015, 06:07 PM
Liked: 0
I really wish Howard would offer a paid subscription model where you can access his entire library of recorded shows over the years up to the current date including live programming. I'd gladly pay for the add on.
ejimster is offline
post #24 of 29 Old 11-18-2015, 04:06 AM
kucharsk's Avatar
Quoted: 1445 Post(s)
Liked: 784
Cassette deck.
kucharsk is offline
post #25 of 29 Old 02-13-2016, 06:28 PM
uncle2000mike's Avatar
Record SiriusXM with new player
https://www.siriusxm.com/player/#vie...=siriuspatriot
Did you figure out a way to record with the new player?
uncle2000mike is offline
post #26 of 29 Old 03-21-2016, 09:29 AM
Liked: 0
Does the XM PCR still work, can you activate it, and does the software still work with Windows 8?
Alternatively, if you stream from a device like a Pioneer INNO to a computer, is there software that can recognize the songs, record them individually, and label them, and save them in a file? I record to my INNO, but they do break down with heavy use, and you lose all of your recordings. I would rather save the music to mp3 and transfer it to my phone.
sumitomo is offline
post #27 of 29 Old 11-13-2016, 01:13 PM
Buchey's Avatar
update on ripping siriusXM
I'm looking to rip from the online player. I have a good solution, using "Streaming Audio Recorder" (easily found on google), which does a fantastic job with sound quality, however it just records one long mp3 file. I want to find a way to have the software name, tag, and split each song into different mp3's using the data from SiriusXM. does this exist?
Buchey is offline
post #28 of 29 Old 11-14-2016, 07:07 AM
andyross63's Avatar
Quoted: 269 Post(s)
Liked: 88
The only way to do that would be to somehow grab the original data stream. Due to the original data being encrypted, most likely the only way to record is the audio output itself. And that recording may not be fully digital either. It may just be feeding the analog output back to the input.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #29 of 29 Old 11-14-2016, 08:03 AM
Super Moderator
DrDon's Avatar
Liked: 2566
You could always do it manually. Remember the start and stop time of your recording, then plug it in here, leaving title and artist blank: http://www.dogstarradio.com/search_playlist.php Highlight and save each song giving it the title from the playlist. Time consuming, but it'll achieve what you're seeking, I believe.
DrDon is online now
Reply XM and Sirius Satellite Radio
