Internet Only Subscription? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-10-2014, 03:41 PM - Thread Starter
Tallen234's Avatar
My sirius radio in my car just died. I really don't want to pay for a new module ($500+), so I was thinking about just trying internet only and use the app in my car.
I've seen a lot of threads on good deals for radio + internet, but no internet only deals.
Does anyone have any luck negotiating for internet only?
Tallen234 is offline
post #2 of 3 Old 06-13-2014, 11:38 AM
Brad Bishop's Avatar
Quoted: 13 Post(s)
If you'll be using it daily then I'd consider the data used on your cellphone plan. You can get an Onyx Plus from Best Buy this week for $65 with a vehicle kit. I think the subscription will be slightly more for the sat radio vs the internet radio ($15 vs $20 or so, I think) but for ≈$5/mo you don't have to worry about your data plan.
Brad Bishop is offline
post #3 of 3 Old 06-14-2014, 01:12 PM
STEELERSRULE's Avatar
Quoted: 60 Post(s)
Liked: 25
Or go on EBay. You can find GREAT units on there for a really cheap prices.
A Stiletto 2 with car and home docks will run you about $200 or less+subscription. That is an awesome price for a unit that can record 100hrs of content, and be moved from inside your house to your car easily.
There are alot cheaper units on there as well. The one mentioned above I am sure is on there. And you could get it cheaper as well.
STEELERSRULE is offline
Reply XM and Sirius Satellite Radio
