Best vehicle head unit "sirius" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-14-2015, 01:44 PM - Thread Starter
Leeboy's Avatar
I think my old sportster 6 is slowly packing it in. Once in a while it doesn't detect the antenae plugged in ( even know it is ...I also tried a brand new antenae and cradle ) funny I don't get that problem with the boom box . Oh well, I looked for another spotter 6 and they don't make them anymore. They have names like " edge" and " onyx" now. I subscribe to the best of XM , as well as I would like replay. What's the good choices in head units these days? Thanks
Leeboy is offline
post #2 of 6 Old 06-15-2015, 07:56 AM
Brad Bishop's Avatar
Quoted: 13 Post(s)
Have you considered:
- swapping out your antenna in your car?
- swapping out the dock in your car?
I like myradiostore.com for odd older stuff. tss-radio.com isn't bad either, just not quite the collection of older stock.
Brad Bishop is offline
post #3 of 6 Old 06-15-2015, 05:38 PM - Thread Starter
Leeboy's Avatar
Yes, I put a brand new antenae and dock ( which I had lying around) and still no antenae found. Works in the boom box though .
Leeboy is offline
post #4 of 6 Old 06-15-2015, 09:52 PM
STEELERSRULE's Avatar
Quoted: 66 Post(s)
Try EBay for more Sportster 6's. I would try EBay for any PNP(Plug and Play) unit. That would be the cheapest way for you to go. If you search on there, I am sure you can find any replacement for your dock/antenna/etc...
Do not know what your spending limit is, but you could consider a Stilleto 10 or 100. They both record. The 10 records 10 hours. The 100 records 100 hours. Sets like a VCR/DVR. I would recommend the 100. Once you begin to record, you would want as much space as possible. BOTH have a 60 min buffer. Plus, on the 100 you can record up to 8 hours straight on music stations for later playback.
Ther
STEELERSRULE is offline
post #5 of 6 Old 10-27-2015, 09:11 AM
Liked: 0
Many modern Sirius radios, such as Stratus 7 and Starmate 8, will fit in your existing docks.
It sounds like your radio has a bad pin connection. That can be repaired. Check our website for repair info.
tssradio is offline
post #6 of 6 Old 11-08-2015, 09:37 PM
pearljammer's Avatar
I bought a new Mini Cooper and it didn't come with Sirius even though I thought all new cars did. I was also curious what the best approach would be to get it in my car?
pearljammer is offline
Reply XM and Sirius Satellite Radio
