Sirius Antenna through wall keystone module - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-15-2016, 04:04 PM - Thread Starter
michaelrj9's Avatar
I am trying to run a Sirius antenna through a wall with a disconnect at the wall plate (keystone module)
I don't see a SMB keystone module so I thought I would try and just cut the ends and put on RCA style plugs but it does not work. Must be too much resistance or something? I get no reception.
I can just hook up the bare wires from the 2 cut ends and it will work without the RCA connectors.
I see they sell SMB connectors to coaxial.
So if I get 2 of those connectors (one for inside the wall and one for outside the wall) and use it with a F type connector will this work or am I going to have the same problems like with the RCA plugs
On Sirius antennas is the SMB a male or female connector?
michaelrj9 is offline
Reply XM and Sirius Satellite Radio
