Replacing 1st Gen Sony Plug 'n Play with Latest - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-23-2003, 08:55 AM - Thread Starter
David McRoy's Avatar
Given that I could get the new, improved version for only $119 at www.xmsony.com after their discount plus XM's current $75 rebate on all Sony receivers, I bit.
Makes more economic sense than going with the Delphi PnP unit and having to replace multiple docking stations, antennas, etc., too.
I'll review the new Sony once I receive it and activate it:
http://www.xmradio.com/catalog/produ...386&type=Tuner
HiDefDave
WPTV/WFLX West Palm Beach, FL
David McRoy is offline
post #2 of 10 Old 06-23-2003, 12:22 PM
JML
JML's Avatar
Your old Sony antennas should all be compatible with any receiver. Obviously not the docking cradles, though.
JML is offline
post #3 of 10 Old 06-23-2003, 12:26 PM - Thread Starter
Why not the docking cradles? The new units are the ssame size and shape. Is there something incompatible about the connections?
HiDefDave
post #4 of 10 Old 06-23-2003, 12:30 PM
JML
JML's Avatar
Oh, sorry... I believe the new sony cradles should be compatible with the old sony cradles, etc. It's just that an XM antenna is an XM antenna and will work with any kind of receiver. Sorry for the confusion.
JML is offline
post #5 of 10 Old 06-23-2003, 12:34 PM - Thread Starter
Whew! You almost gave me a heart attack there, JML!;)
HiDefDave
post #6 of 10 Old 06-27-2003, 06:36 PM
jspratley's Avatar
The new one is a huge improvement over the old. The old had a terrible display and was next to impossible to read. They now give you 20 presets instead of 5 which was ridiculous considering there are 100 channels. The new one also allows you to directly enter the channel number. Before you might have to scroll through 80 channels or more to get to the one you wanted.
jspratley is offline
post #7 of 10 Old 06-27-2003, 09:51 PM - Thread Starter
Here's a link to a thread that I started after I started using the second generation Sony plig-and-play XM receiver:
http://www.avsforum.com/avs-vb/showt...hreadid=274746
HiDefDave
post #8 of 10 Old 06-29-2003, 09:02 AM
joe12401's Avatar
i'm new to xm, found a sony drn-xm012c at best-buy on clearance for $49, regular price $249, is this the secong gen or old first gen with the problems? thanks
joe12401 is offline
post #9 of 10 Old 06-30-2003, 08:22 AM - Thread Starter
It was the first generation receiver that was too hard to read and had only 5 presets. The second generation receiver fixes everything.
HiDefDave
post #10 of 10 Old 06-30-2003, 08:38 AM
joe12401's Avatar
thanks, i think i put the model number wrong, drn-xm01c2
the manual says it has 20 presets
joe12401 is offline
Closed Thread XM and Sirius Satellite Radio
