stupid ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-30-2006, 11:24 AM - Thread Starter
mhbbkb's Avatar
I have 2006 F-250, how do you get the radio to find a channel that is not broadcasting when there is no manual knob ?
mhbbkb is offline
post #2 of 4 Old 01-03-2007, 10:40 AM
STEELERSRULE's Avatar
Quoted: 60 Post(s)
Liked: 25
Your question is a bit confusing.
You don't know HOW to manually tune to a radio station on your trucks radio? ANY RADIO can be manually tuned.
But if you are asking which radio stations in your area are not being used, click on the below website, type in your location, and they will list which radio staions/frequency's in your area are not being used:
http://www.radio-locator.com/cgi-bin/vacant
STEELERSRULE is offline
post #3 of 4 Old 01-03-2007, 10:53 AM
ClubSteeler's Avatar
Or simply hit SEEK....
If you are on 99.1 and you hit seek and it stops on 99.9, you now know that 99.3, 99.5, and 99.7 did not have signals strong enough for your radio to lock on.
ClubSteeler is offline
post #4 of 4 Old 01-03-2007, 05:36 PM - Thread Starter
mhbbkb's Avatar
What I am tring to say is it automatically tunes into a strong signal, how do you stop it in between there is no manual knob, there is only a seek and scan button, I have looked at all the menu optitons and cant find how to turn off aoto tune. Thanks
mhbbkb is offline
Reply XM and Sirius Satellite Radio
