Taking apart Sportster SP-R2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-05-2007, 04:26 PM - Thread Starter
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
My display no longer lights up unless I press down on the radio.
Would like to take it apart to look at it more closely?
Anyone else try this?
dm145 is offline
post #2 of 2 Old 01-15-2007, 05:59 PM
go_broncos's Avatar
yeah, I popped open my old sportster to look at the antenna inside. remove the two screws. Then you need a very small screw driver to pop out 4 areas where it is notched in. If you are looking at it and the screws were on the bottom, the notches are at 10 oclock, 11 oclock, 1 oclock and 2 oclock (11 and 1 on top about 20% of the way from each side). 10 and 2 on the bottom about 20% of the way down.
Aaron
Pioneer SD643HD5
Oppo 970
Denon 1803
M&K K7's (3), K5's (2)
M&K V76 sub
go_broncos is offline
Reply XM and Sirius Satellite Radio
