XM Model w/ Digital Output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-15-2007, 06:29 PM - Thread Starter
zx6rpete's Avatar
Anyone know of a model with a digital out that I can run to an external DAC? I have a Skyfi2 with home and car dock. I really love XM radio but the sound quality in the home dock sounds like a$$. Thanks in advance.
zx6rpete is offline
post #2 of 5 Old 08-21-2007, 02:20 PM
snapdemon's Avatar
Might want to check the forums at XMFan.com I know that there are conversions available for some units that require soldering skills but some can beordered with the unit already complete. I had an XMPCR and I know that it had a daughterboard availabl to give it a toslink output forr around 50 bucks as a DIY project or you could send it somewhere to have i done.
snapdemon is offline
post #3 of 5 Old 08-21-2007, 06:38 PM - Thread Starter
zx6rpete's Avatar
Thanks but I stumbled upon a Squeezebox plugin that allows me to sign in on the internet then wirelessly send the music to my Squeezebox. The sound quality is a hundred times better than my skyfi2 homedock!!! Plus it also streams all of the station, song, and preset info. I'm still trying to decide on a DAC and I'm sure that will increase the sound quality even further.
zx6rpete is offline
post #4 of 5 Old 08-28-2007, 06:40 AM
JOHNNYV.3's Avatar
I own the Polk Audio xrt12, which has a digital output, but I'm not sure if it would work for what your trying to do? At any rate it is a home audio component and would give you much better sound.....
JOHNNYV.3 is offline
post #5 of 5 Old 09-08-2007, 07:00 PM
jlin's Avatar
you're better off using digital out of Directv receiver. XM sounds a lot better on Directv than ANY XM receiver out there due to wider bandwidth.
jlin is offline
Reply XM and Sirius Satellite Radio
