I want to record SOME music from Sirius - AVS Forum | Home Theater Discussions And Reviews
Old 12-28-2007, 02:50 PM - Thread Starter
enticer's Avatar
using my BoomBox SUX1 and a Sportster 4. Is this possible? I do have TimeTrax, but this software from what I have tried will not work. Besides this software has gone by the wayside
JB
PS.....how about recording from the internet through Sirius?
enticer is offline
Old 01-04-2008, 01:49 PM
hendooman's Avatar
You can record with Replay AV...it is a nice little program.
hendooman is offline
Old 01-04-2008, 02:48 PM - Thread Starter
enticer's Avatar
You are correct...it is a nice little program. I guess I want my cake and eat it also. But is is too bad that it does not break it up and title the song also. I guess that is asking too much.
But the demo mode was enough to record and convert to try the program. now I'll go and checkout the price.
But a program with a little more control would be really nice
Thank you
JB
enticer is offline
Old 01-08-2008, 11:33 AM
goingsking's Avatar
I found something called freeradio or something like that (I will post when I get home tonight) that does a really good job. We can't have streaming audio at work so now I just listen to sirius at home and save it to mp3 files and take it to work with me playing it thru my radio's aux port. One nice feature is you can adjust the quality. I had mine set to 32kb or something like that because that was the limit that sirius provided and it works fine. I have about 2 days of stuff and it only used up about 75mb
goingsking is offline
Old 01-09-2008, 11:09 AM
adam368's Avatar
Try SIRIUS Recorder at backpocket dot com
Adam
5040 (1) - 00004-54831-82841 (120GB upgrade)
5040 (2) - 00004-54831-37689
adam368 is offline
Old 01-09-2008, 04:50 PM
goingsking's Avatar
I am using a package called freecorder and it works well
Old 01-09-2008, 06:45 PM - Thread Starter
enticer's Avatar
Thanks to all....alot of good info coming in. But I still have not seen anyting that will work with what I have or anything that records like Time Trax or SX Recorder with online streaming
Keep it coming, I know there has to be something out there
enticer is offline
Old 01-09-2008, 07:41 PM
goingsking's Avatar
Let me get this correct, do you want to record of the on-line sirius (which is free with a subscription) or directly from the radio. I just log on and let it rip. Every 1:30 minutes sirius askes me if I am still listening. I don't know how you can record from the receiver directly.
Old 01-12-2008, 07:45 PM
GqMagic's Avatar
I want to record sirius and the audio cd from Dish Network, I'm going to record on my dvr, then to a cd recorder to play in my car. These computer programs mentioned are they a good option for good sound quality?
GqMagic is offline
Old 01-17-2008, 01:39 PM
hendooman's Avatar
Thank you
JB
when you used it, did it record from the stream or what was coming through your speakers? It seems to be recording what was coming from the speakers...something funky with the log in, maybe I was doing it wrong. I recored some dead shows off sirius, I haven't listened to them yet, just stockpiling them for future editing. It is going to be quite a chore to break them up into songs, but it should be fun.
Old 01-17-2008, 01:45 PM - Thread Starter
enticer's Avatar
When I did use it. .... Yes, it recorded what was coming through the speakers. Being used to Time Trax, I was hoping to separate the songs...besides labeling them. The program did not. It recorded what it heard from Start Recording to when you stopped.
I have since located a program that works with Sirius and does (hopefully) what I am looking for. I do not have all the hardware at this moment
enticer is offline
Old 01-17-2008, 02:31 PM
hendooman's Avatar
what is this new program?
Old 01-17-2008, 05:13 PM
GqMagic's Avatar
What do I need if I want to record from my dish network dvr to my imac?
GqMagic is offline
Old 03-18-2010, 08:31 AM
StreamRecorder's Avatar
Replay Music can split and tag songs, but it records from sound card.
Replay AV can get a digital copy of the stream, so I prefer to use it.
StreamRecorder is offline
