Good signal but Sirius cuts in and out... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-17-2008, 06:52 PM - Thread Starter
CrushedBeerCan's Avatar
I have the Sportster 5 on a cradle with an indoor/outdoor antenna. The signal strength is full bars on the Terrestrial and 3 "squares" on the satellite signal. Even with a "good" signal it cuts in and out constantly. Is my radio defective or is this normal?
When going through Hell, keep going -- Churchill
UMC-200, DDRC-88A, Anthem MCA 50
GoldenEar Triton 5, GoldenEar SuperCenter XXL, GoldenEar SuperSat 3
SVS PB-2000 (dual)
Pioneer Kuro 5080
CrushedBeerCan is offline
post #2 of 7 Old 01-17-2008, 07:18 PM - Thread Starter
I am seriously getting pissed off at this. There isn't a cloud in the sky. If this IS satellite radio it sucks.
SVS PB-2000 (dual)
Pioneer Kuro 5080
post #3 of 7 Old 01-18-2008, 01:09 PM
derek1079's Avatar
Are you talking about in the car or in the home? If you are getting full TERR signal, then you should be getting good reception.
How are you connecting your radio to an output source? If you trying to use the built-in FM Modulator, it is very weak and causes a lot of static. You will have to use an FM Direct Adapter, Auxiliary input into your car stereo, or cassette adapter.
derek1079 is offline
post #4 of 7 Old 01-19-2008, 06:04 AM - Thread Starter
This is in my home with an indoor/outdoor antenna. So I have 1/8 to RCA jacks into my AV switch. The weird thing is it is good one day then bad the next. I have no idea.
SVS PB-2000 (dual)
Pioneer Kuro 5080
post #5 of 7 Old 01-21-2008, 08:38 PM
ozziegn's Avatar
Quoted: 36 Post(s)
Sirius sucks seriously when it comes to reception. my Sirius connection (when I had them) use to blink in and out BEFORE and DURING when I'd be coming under some trees. that and the fact that the quality of my reception varied quite a bit depending on the time of day.
meanwhile, my XM connection hardly ever goes out.
Samsung UN65HU8550 65" 4K goodness
ozziegn is offline
post #6 of 7 Old 01-22-2008, 06:59 AM
ricky_rocket's Avatar
So your antenna is physically inside your home ? I have a similar setup. There are bad days (cloudy) but in general 99% of the time it works great. What area of the country are you in, are you near a big city or out in the sticks ?
ricky_rocket is offline
post #7 of 7 Old 01-22-2008, 08:46 AM
ClubSteeler's Avatar
Sirius has superb reception.
In listening a minimum of 4 hours a day, every day, for over a year, I have yet to have 1 single drop out in my home.
I love how people judge this technology without understanding it.
First of all, is your antenna outside? This is satellite radio. The frequencies used do not pierce through roofs or walls. Do you ever see DirecTV satellites in someone living room? NO.
Secondly, it IS possible to receive inside if you are near a ground repeater, but once again, this is not terrestrial radio, it is satellite radio. Ground repeaters do not nearly have the power of a strong FM transmitter, and unless you are one of the few that are lucky enough to live very near a repeater, then get it from the satellite. It is, after all, satellite radio.
Finally, Sirius satellites are in a highly elliptical orbit. This gives them the height and versatility for superior reception to XM in a car. On the other hand, XM's geostationary satellite is much more convenient for in home reception. If you can see the XM sat now, you always will. If you simply put your Sirius antenna in a window, you might see it now, but as it moves your roof overhang, walls, etc... might block it out.
Sirius has 3 sats, 2 active at a time in the northern hemisphere. Place your antenna outside, in a direction that can see high into the open sky in the direction of Minnesota. Point towards Minnesota and you'll be fine as long as you can also see a bit north and south of Minnesota, which is the middle point of the figure-8 shaped sat path with repect to you.
If you still have reception iussues, it has nothing to do with Sirius or the satellites. Then you have to troubleshoot. You can have a bad antenna jack, a bad antenna, a lose cable, a lose connection to the dock, a faulty dock, a damaged radio.. .etc...
The bottom line is these signals are always broadcasted from the sats. I don't care if you're in Maine or california, you're still looking at the same sats. I have used my radio through tropical storms with 70MPH winds and amazingly hard florida rain without a single dropout.
There's no such thing as poor reception. There's poor equipment, poor antenna placement, and way too many people trying to listen to "terrestrial" sirius, but there's no such thing as bad Sirius reception.
If you live inside a big city with big buildings and you HAVE to relay on a terrestrial repeater, and that repeater is having technical difficulties, than maybe nothing you can do. Otherwise for the other 95% of us, look at the sats and you'll be fine.
Good luck. If you still have problems, let us know the specifics:
Model of radio?
How many "bars" of sat and terr signal?
What happens on the screen during a drop out? Is there a message like "Antenna not found" or "Acquiring signal"?
Where is the antenna?
Have you replugged all jacks?
Have to reseated the radio in the dock?
Did you do the radio reset (some models)?
Did you try another antenna, and did it help?
Did you try another dock?
etc....
Good luck.
ClubSteeler is offline
Reply XM and Sirius Satellite Radio
