Panasonic DMR hard drive data recovery - It CAN be done!! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 179 Old 04-15-2014, 03:40 PM
mickinct's Avatar
Quoted: 206 Post(s)
Liked: 902
Sorry to say that the eh55 and eh75 drives can not be done this way tried many many times, no luck.
MickinCT
mickinct is offline
post #152 of 179 Old 04-15-2014, 03:47 PM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
Those instructions seem to have been written prior to the EH-55/75v models, Panasonic must have changed something in later models :(
jjeff is offline
post #153 of 179 Old 04-19-2014, 04:42 AM
Chanbara's Avatar
Like others before me, finding this thread was an answer to my prayers. After my much loved and much used 10 year-old Panasonic DMR-E85H recorder became stuck in an endless "Please Wait..." loop, and being told by the repair technician that it needed a full drive replacement and that there was no way to get anything off of my 120GB (really 111GB) HDD, I was sick. Then I found this thread and suddenly there was hope that I could still get my lost recordings.
Reading through the various posts it seemed a daunting task at first, particularly when it looked like I’d need to gather up and work with Hexadecimal codes, but then as I continued to read through more posts by posters like worley45, im2020, and 0x1BBE898 it looked much easier than expected. A huge thanks to all who contributed to creating a process to salvage our HDDs. Absolutely brilliant!
I followed the instructions in the post by PC7211, and was able to get a full image of my HDD. I installed and ran the python scripts and everything was going smoothly until I hit a snafu during the final export process.
It exported the first 93 files which totaled up to 11GB (I have a lot of short segments and interview clips from various programs), before the script spit out the following errors and stopped running:
Exporting file #94
Traceback (most recent call last):
File "dvr-recover.py", line 1161, in
Main().run()
File "dvr-recover.py", line 1152, in run
func()
File "dvr-recover.py", line 1127, in export
export_file(chunk, index)
File "dvr-recover.py", line 1117, in export_file
export_chunk(reader, outf, chunk, 1)
File "dvr-recover.py", line 1101, in export_chunk
speed = float(chunk.block_size) / float(delta)
ZeroDivisionError: float division by zero
I’m really hoping someone can tell me what I can do to get over this hurdle and have the script run successfully so that it can hopefully export the remaining 100GB.
Any help would be much appreciated. Thanks in advance.
Chanbara is offline
post #154 of 179 Old 04-19-2014, 01:54 PM
mickinct's Avatar
Quoted: 206 Post(s)
Liked: 902
YOUR machine is repairable, send me a PM for more info.
MickinCT
mickinct is offline
post #155 of 179 Old 04-19-2014, 05:36 PM
Chanbara's Avatar
Really? Man, I wish I'd known about this a few weeks back. I've already gotten replacements for my recording needs, so at this point my main goal is to just hopefully get the content of my HDD copied over. Still, I'm intrigued so will follow-up with a PM.
I decided to try the process over again, this time with min_chunk_size set to something higher than 0, hoping this might make the script ignore what looks to be a problematic spot. Unfortunately, 6 hours later I got the same error at the same spot (after copying 11.7GB of data - first attempt got 11.6GB). The only slight difference was in the number of files created (71 instead of 93).
Here's what it spit up when it stopped running:
Exporting file #71
Part #1: 0.03s (7741.96 blocks/s; 15.12 MiB/s).
Main().run()
func()
File "dvr-recover.py", line 1109, in export_chunk
export_chunk(reader, outf, chunk2, part+1)
I can't help thinking that if the script could just skip over this file/section on the HDD, it would keep going and copy over the rest. I saw that the author of dvr-recover had a contact email in the readme file, so I'm hoping he may have a solution, or someone else who sees this will.
Keeping my fingers crossed...
Chanbara is offline
post #156 of 179 Old 04-21-2014, 11:36 AM
Chanbara's Avatar
UPDATE: I've made a little progress, in that I was able to create a script to run the export command on each block one by one.
The answer to how to do this was in the readme file:
"You can also specify a chunk id to export. In this example the script would export only the chunk with the id 4 (including the chunks which should be concatenated to this one)."
python dvr-recover.py export 4
I'm not sure how I missed it, but taking this into account I created a DOS batch file called finish.bat containing one line for each of the remaining chunks:
python dvr-recover.py export 72
python dvr-recover.py export 73
python dvr-recover.py export 74
python dvr-recover.py export 75
etc...
I then ran it using the following command which put all the output messaging text (including error messages - so I could check if any failed) to a log file:
finish 1> log.txt 2>&1
Once it was complete I got a total of 1598 files and 172 GB of data recovered. This had me scratching my head since my HDD is only 111 GB. Going through the files, I spotted more than a few duplicates (some full, some partial), so it's hard to tell how much I truly got extracted.
When I started putting the pieces together on a bunch of hour-long programs, I noticed something even stranger and more troubling. All of them only had the first 20 minutes or so. Some of them were split up into multiple files, and a couple were single files, but they're all missing the last 38-42 minutes!
The log.txt file had a full rundown of what transpired so I was able to check if any other blocks had the same ZeroDivisionError that # 71 did. All told there were 110 exports that failed due to this same error, which I can only assume is a bug in the script.
Anyway, I'm still hoping to hear back from the author of the script, or someone else who may have an idea how to fix this bug or at least offer an explanation as to why I'm getting these ZeroDivisionErrors when no one else who previously used it did...
Chanbara is offline
post #157 of 179 Old 07-15-2014, 11:44 PM
Liked: 0
Hi,
I have Panasonic DMR-HWT130. I've tried the Python script method but no chunks are found. Anyone had any success with this format of Panasonic drive or ideas as to how to change parameters, script etc
Phil Read is offline
post #158 of 179 Old 07-16-2014, 04:48 AM
jjeff's Avatar
Quoted: 766 Post(s)
Liked: 268
Looks like that one is a HDD only recorder and HD at that. Are your programmes HD or just SD? The format may be different depending and even SD may be in a different format than the DVD standard MPEG2 this thread deals with,
http://www.amazon.co.uk/Panasonic-DM.../dp/B00BYUGN74
jjeff is offline
post #159 of 179 Old 07-16-2014, 08:59 AM
Kelson's Avatar
Quoted: 1984 Post(s)
Liked: 1172
It is probably recording the digital transport stream and not encoding at all. But wow, look at this from the description in the link you post:
DLNA Server and Client
Not only can the recorder act as a DLNA client letting you enjoy music, videos or digital photos from a Windows 7 (or above) PC for example, but it can also be a DLNA server that streams recordings from its internal hard disc drive to other DLNA devices in the home, such as a networked Panasonic Blu-ray player or TV. Recorded TV programmes*, HD video content or digital photos, saved on this model's hard disk drive, can also be accessed and enjoyed over your home network. *Some TV programmes may be restricted for copy protection purposes.
Multi-room Streaming of Live Broadcasts
It is possible to watch broadcasted TV programmes live in any room of the house that is equipped with a DLNA compatible TV or Blu-ray player on your home network. Access to the recorder's twin tuner is possible meaning that you can select a TV channel to view while someone else is watching a different channel.
Holy Crap, that is an unbelievable recorder. It's a server allowing multi-room viewing (MRV) of your recordings to any DLNA client -- just about every smart TV, Blu-Ray player and media streamer you can buy today is a DLNA client. It also shares its tuners. That is MRV TiVo-style without having to buy a $250 TiVo Mini. Screw the clear QAM, all they need to do is put dual ATSC tuners in it and sell it in the US for a price close to $285 to match the UK price (£164.82) -- it would bury the DVR+ in a heartbeat.
Why not here?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #160 of 179 Old 07-16-2014, 09:29 AM
Liked: 0
The DMR-HWT130 works by moving recorded programs from its own internal HDD to an external USB connected HDD. You can move programs from HDD to USB HDD and back the other way.
I've recorded in HD and SD, for the purposes of this test I've moved a few SD recorded programs from the internal HDD to the USB HDD, made an .img copy of the USB HDD and ran the python scripts against the .img file. The scripts run to completion put don't seem to find anything. I've put a few "print" commands in to check where the script looks for the relevant hex codes for the MPEG headers and it looks like it finds the header code but not any subsequent matching "bits"
post #161 of 179 Old 07-28-2014, 11:47 AM
Liked: 0
Originally Posted by Rob Day View Post
Just wanted to add my thanks to seeto and braincon for suggestions on getting a Panny HDD to work in a different machine.
My DMR-EX85 suffered the U81 fault and, over-estimating my skills at electronics repairs, I trashed the main board attempting to undertake the repair. (Hint - if in doubt, there are people on Ebay who will do it for you pretty cheap!) I knew a friend had the same machine sitting idle and they were willing to sell it to me cheap. I then wanted to get the HDD from my old machine into the working machine. I was disappointed but not too surprised to get the "format" request. I was about to give up on all my old recordings (including camcorder footage that's a real grind to copy from tape) when I spotted seeto's and braincon's posts. Nothing to lose, so I took the seeto approach. After a few failed attempts I concluded that I needed to get as far as the machine actually starting the "format" i.e. don't power down the drive after the first "OK" - I had to go past the "are you really sure?" question. Scary! I then pulled the power to the HDD as fast as I could - less than a second I'd guess. Voila - next time I powered it up, no "format" question and all the old recordings are still there. Now, where's my stack of blank DVDs...
Caveat - anyone trying to replicate this does so entirely at their own risk! And don't even think about getting that HDD power connector off the EX85 without unclipping & removing the front cover (there's nothing wired to it, so it's easy to remove).
I can 100% verify that this works for swapping HDD between DMR-EH55. I powered up the DVR, it booted up to display "UNFORMATTED" on the LCD and asked me to press ok to format. I pressed ok, and as soon as the screen started to change, I unplugged power to the HDD, then unplugged the DVR. Once I plugged everything back in and powered on it was ready to use with all my recordings in place. I did this consecutively on two machines and each time it only took one attempt.
JJonn is offline
post #162 of 179 Old 09-22-2014, 05:18 AM
Liked: 0
Hello, first I apologize for my English, I have a panasonic ex77, I tried with python script, but only get 15 seconds of video and audio.
For example I extract a file of one hour, but only see 15 seconds then crashes, the player still has time, but the video and audio are hung.
I've got more than 50 files of different lengths and all have the same problem.
I've tried changing, min-chunk-size and blocksize, unsuccessfully
any ideas?
can anyone help me?
Thank you.
akg2008 is offline
post #163 of 179 Old 09-23-2014, 01:37 PM
larryccf's Avatar
Quoted: 108 Post(s)
out of more than slight curiosity, does the panasonic Panasonic DMR-HWT130 encode it's recordings so they can only be played back on a Panasonic DMR-HWT130?
That HD recording ability plus the ability to move recorded video to an external hard drive does make it attractive - what i'm wondering is if recordings moved to an external hard drive can be played back thru windows media center independent of the Panasonic DMR-HWT130?
i checked the owner's manual and thought i had the answer, then realized i didn't
'A good police force is one which catches more crooks than it employs.' quote, Sir Robert Mark, Commissioner of the Metropolitan Police UK
larryccf is offline
post #164 of 179 Old 09-28-2014, 03:26 PM
Liked: 0
Hey there guys!
Just posting to see if someone can help me. Im having to put a new Harddrive in my Panasonic DMR-E95H. It originally came with a Samsung 160 gb harddrive and ive tried putting in a smaller 80 gb drive and all im getting is a "Please Wait" message on the dvd player. The message has been there for hours with no luck. From my understanding i need to get a drive thats Equal to or greater than the gigabyte size for the recorder to format the disk.
My question is Do i need to get the same brand and size of the old harddrive that it came with? And also does it matter if the drive is 7200 rpm?(I think maybe the old one was 5400 rpm.)
I really love this recorder and would be wonderful to keep using it!
Im stuck on this and need some help. Thanks!
ls1xxx is offline
post #165 of 179 Old 09-28-2014, 06:15 PM
mickinct's Avatar
Quoted: 206 Post(s)
Liked: 902
Originally Posted by ls1xxx View Post
Hey there guys!
Hello sent member a PM.
MickinCT
mickinct is offline
post #166 of 179 Old 11-14-2014, 02:19 AM
Liked: 0
Hi,
I wrote a program to recover movies from a Pioneer DVR-633H reading its file format structure and as dvr-recover by Haliner also worked for your Panasonic recorders, I was curious if the filesystem structure is the same there so that my tool for Pioneer also works for your recorders? Can someone try this out?
Here is the project: code.google.com/p/pioneer-rec/
Thank you!
leecher1337 is offline
post #167 of 179 Old 11-14-2014, 03:32 PM
Liked: 0
I too had a problem with Panasonic hard drive DVD recorders being accidentally formatted. One was a DMR-E85HS that I accidentally reformatted. I did not record anything over it, I set it aside for future repair. The second was a DMR EH50 and I woke up a week ago and it was asking me to confirm the reformatting (!). I have no idea how that one happened unless I was sleep walking! I tried sseeto's method to get the machine to recover the harddrive's contents but after I unplugged it the power supply apparently died! Set it aside to try to rescue later. Well, at least it's a wake up call to back up everything I recorded on my remaining machines!
mattpak is offline
post #168 of 179 Old 11-14-2014, 05:13 PM
Liked: 0
any ideas?
Can you provide your image somehow so that I can check? I can give you a FTP server to upload, if that is needed. As Private messages are not possible for users with post counts <15, you can send me an e-mail to the address given in the README of my recovery tool.
Maybe I can help you...
post #169 of 179 Old 02-23-2015, 07:28 AM
Liked: 0
Originally Posted by PC7211 View Post
Hi everyone,
I know this thread is a bit old now but boy it's helped me. I just wanted to thank everyone involved in it especially the ones who created the python script.
After reading every bit of this thread - parts of it several times, I managed to to successfully recover some family movies from a Panasonic DMR-XW350.
Along the way I made a few mistakes which wasted many hours so here's a rundown of the seccessful procedure I used in hope that it saves the next person some time:
Thanks again,
Paul.
Thank you for this Paul, it was really helpful and I have successfully rescued lots of mpg files from the disk of my friend's DMR-EX75 which recently died for the 2nd time and couldn't be resusitated with a soldering iron like last time.
One final question. I now have lots of files but no titles or information. Is there any way to recover anything such as the date of the original recording, etc?
Sally
SallyH is offline
post #170 of 179 Old 02-24-2015, 03:45 PM
PC7211's Avatar
Hi Sally,
Sorry I'm not sure if there is a way you can get any more info like dates and filenames back. Maybe one of the people who created the script can help??
PC7211 is offline
post #171 of 179 Old 03-03-2015, 10:19 AM
Liked: 0
Hi,
Someone was nice enough to send me an image of a Panasonic HDD.
I tried to write 2 little utilities to rescue the movies from a HDD image, maybe you can give them a try and tell me if they do work for your image too?
code.google.com/p/panasonic-rec/
(Prepend https in front of the URL, I'm unable to post links with a post count <5 unfortunately)
leecher
post #172 of 179 Old 09-28-2015, 04:51 PM
robdca's Avatar
Liked: 0
save E85H HD to Magnavox?
Is it possible to take the HD out of my 'dead' E8H and install it into my new Magnavox DVR to save the files I can no longer access?
robdca is offline
post #173 of 179 Old 09-28-2015, 05:07 PM
Kelson's Avatar
Liked: 1172
No.
- kelson h
Kelson is offline
post #174 of 179 Old 03-23-2016, 09:46 PM
Liked: 0
Send a message via AIM to nickjuly4 Send a message via Yahoo to nickjuly4
Originally Posted by profhat View Post
Ok... I need to ask this: has anyone tried the Python script with a Magnavox HDD?
I tested this out with my Maganavox 513H hard drive.
The manual method for recovering videos seems to work fine as I was able to recover videos, but is too time consuming to get everything. The script does not work.
I created an image file of my Magnavox 513H's hard drive by opening the hard disk in HxD and saving it as a .img file. I'm not sure if this is the recommended way of creating the image of the disk but I'm still able to manually recover recordings from the disk image as well so I don't see why this wouldn't work.
The script seems to not work with my Magnavox 513H's hard drive (image). It just looks through the whole image for several hours but never find any chunks. From looking around the Python code it seems that it's failing to find the MPEG header when it goes to the mpeg_header() function, which takes a bunch of data (blocksize) and expects the MPEG header to be at the beginning of it and possibly the Magnavox DVRs don't have it at the beginning of the data using the specified blocksize (2048) or maybe it just doesn't like my .img file for some reason..
nickjuly4 is offline
post #175 of 179 Old 04-05-2016, 01:13 PM
profhat's Avatar
Gee... Thanks man!
profhat is offline
post #176 of 179 Old 05-17-2016, 10:20 AM
Liked: 0
Gutted, my EX85 came up with the U81 error today, no problem I thought - I'll whack the drive in the spare 75 I have upstairs.
Then I found this thread.
I tried the pull the HD power trick but no joy and it now just says the drive is blank. I guess it isn't but what massive amount of work to recover the files. It wouldn't be so bad but a month ago I put a load of stuff on there from my skybox after cancelling my sky subscription
retrogeezer is offline
post #177 of 179 Old 02-26-2017, 11:25 AM
geosailor's Avatar
Angry DVR in wait state
I have a Pioneer DVR 633h that goes into a continuous wait & reboot state. None of the menu buttons work nor does a reset.
I would appreciate any help that anyone can provide.
Geosailor
geosailor is offline
post #178 of 179 Old 05-29-2017, 12:23 PM
Liked: 0
My family's Panasonic DMR-EX95V recently developed a fault. It will not power up. I took the cover of the unit off to have a look, and it seems that three capacitors on the power supply board have "popped". I downloaded the service manual of the DMR-EX95V with a view to disassembling the unit and replacing the capacitors myself. However, one thing concerns me. The service manual seems to imply that if I disassemble the unit, replace the capacitors and reassemble the unit, then I will be forced to reformat the HDD upon powering up (and thus losing the films and TV programmes on the HDD). Is this true? I understand from this thread that taking the HDD from my broken unit and fitting it into a working unit will lead to a mandatory reformatting. Will repairing the power supply board of this unit also lead to a mandatory formatting?
Sabreman64 is offline
post #179 of 179 Old 05-30-2017, 01:01 AM
Church AV Guy's Avatar
Quoted: 117 Post(s)
Liked: 89
Well, I don't know anything about the DMR-EX95V machine, but I have replaced capacitors in a few of my machines, and a HDD reformat was never required. I don't see why it would be required, but these things have squirrely requirements sometimes, so I wouldn't categorically rule it out. MICKINCT would know better.
That capacitor issue is pretty common with these units as they age.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
