Panasonic DMR EH57 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-11-2008, 06:17 PM - Thread Starter
juliex's Avatar
I have just purchased a Panasonic DMR EH57 and see that on the front cover of the manual that it will only play DVDs labelled 4 or All (I purchased it in New Zealand and 4 is the zone for NZ). Does anybody know how to get it to play DVDs labelled 1 and 2 or if this is even possible?
juliex is offline
post #2 of 2 Old 07-14-2008, 10:40 AM
mmihalik's Avatar
Your DMR-eh57 is the baby brother of my eh67.
You might be lucky, and the player may just work with region 1 or 2 DVDs; I purchased mine from a US reseller, and though it was marked as Region 3 only, it worked fine with Region 1 discs.
Check the instructions at the following website:
http://www.dcevolution.net/panasonic/
Though there is a focus on some specific DVD players, there is also a recommendation that the remote control mod (using a different learning remote) can make most any Panasonic recorder or player region free.
Unfortunately, there is no way to simply use the eh57 front panel or remote to do this. You need to use a remote that is able to send out the Panasonic service code. There is also a website in the UK that goes into more detail on region code modifications:
AV Forums Hack thread
Mike
M2 in OR
we live in interesting times
mmihalik is offline
