No initial setup menu with refurb Philips 3575H/37 - AVS Forum
post #1 of 3 Old 07-25-2008, 06:40 PM - Thread Starter
adagiopop's Avatar
I am not getting the initial setup menu and after reading some of the other posts on this, I think it mine is setup correctly (but you never know).
I have the RCA cables running from AV OUT to AV IN on the TV.
I also have the coax cable running from the antenna to the 3575 and another one over to the TV, but I don't think that matters.
When I have both TV and 3575 on and switch to AV1, I get a blue screen. If I unplug the cable the blue goes away and TV shows black. If I plug it back in, I get blue, so it seems connected.
If I don't do anything for awhile, I get the word Philips gliding around my screen (manual says there is a screen saver), so that seems even better evidence that my connections are right.
However, no initial setup menu or any menu at all.
If I leave the TV on and power down/up the 3575, I get a nice Philips screen for a few seconds, then E1 (Rear) for a few seconds, then back to my blue screen. E1 also displays on the front of the 3575.
Suggestions appreciated before I return this.
adagiopop is offline
post #2 of 3 Old 07-25-2008, 06:55 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 132
Did you press the SETUP button, 3rd button down from top right (larger button)?
That opens a list of SETUP option for setting clock/date and Channel > Auto Channel Preset so you can scan for channels. In that menu, select Antenna if you're on an antenna, or Cable (Amalog/Digital) ... even if you only subscribe to analog cable.
See this post on Scanning for channels.
See if this helps you get started?
wajo is offline
post #3 of 3 Old 07-26-2008, 05:21 AM - Thread Starter
adagiopop's Avatar
Thanks wajo. That solved my problem and is greatly appreciated.
Perhaps I should not have tried this so late in the evening after a long day, but it would have helped if the manual had mentioned the setup button.
User Tag List
