Panasonic DMR-EH57 - Why not all over this forum? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-29-2008, 09:23 PM - Thread Starter
igreg's Avatar
Quoted: 270 Post(s)
Liked: 47
Given those that say they are disappointed with Panasonic no longer making DVD recorders with a hard drive? From all accounts this records NTSC as well as PAL.
Panasonic DMR-EH57 1080p
PAL/NTSC Code Free DVD Recorder with 160 GB hard disk
Records in "ALL" regions format for worldwide compatibility
The DMR-EH57 is a great CODE FREE ALL ZONE DVD player too!
igreg is offline
post #2 of 12 Old 07-29-2008, 09:31 PM
Guest
Quoted: 38 Post(s)
Liked: 198
One reason might be that the tuner is:
"Built-in PAL/Secam DK, BG, I, DK TV tuners"
7558037 is offline
post #3 of 12 Old 07-29-2008, 09:35 PM - Thread Starter
igreg's Avatar
Quoted: 270 Post(s)
Liked: 47
Ads say that it "Records in "ALL" regions format for worldwide compatibility". Records in PAL or NTSC on DVD-R DVD-+R, DVD-RW, DVD+RW, and DVD-RAM - Regular or Dual Layer discs
Not true? Thanks.
igreg is offline
post #4 of 12 Old 07-29-2008, 09:44 PM
Guest
Quoted: 38 Post(s)
Liked: 198
Not true? Thanks.
I figure their marketing words must mean it can record an NTSC signal via line input and create PAL or NTSC discs, but unless you can find a spec that says it has a NTSC or, more important for U.S., an ATSC, tuner, don't think it'll work here as most people would want? Might work in a satellite system where a tuner won't work anyway, just not sure tho. Just be careful and ask lots of questions, and hope you get good answers.
7558037 is offline
post #5 of 12 Old 07-29-2008, 09:53 PM - Thread Starter
igreg's Avatar
Quoted: 270 Post(s)
Liked: 47
Thanks for the reply. I subsequently saw this in a note at the bottom of the page:
NOTE: This model doesn’t have NTSC (American) Tuner. You will not able to record satelite broadcasting programs using NTSC tuner.
Did sound too good to be true. More of a market for HDD recorder outside of the USA?
igreg is offline
post #6 of 12 Old 07-29-2008, 10:07 PM
Guest
Quoted: 38 Post(s)
Liked: 198
NOTE: This model doesn't have NTSC (American) Tuner. You will not able to record satelite broadcasting programs using NTSC tuner.
Yes, EVERYBODY ELSE gets all the good stuff!
7558037 is offline
post #7 of 12 Old 07-30-2008, 06:55 AM
Kelson's Avatar
Quoted: 2028 Post(s)
Liked: 1209
All recorders record in "ALL" regions format. That just means it doesn't assign a region code to the recording so that it is playable on any player worldwide that will play that particular video format. So it's a nothing statement. Kinda like: is equipped with on-unit power button to allow operation without remote.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #8 of 12 Old 07-30-2008, 04:26 PM
Church AV Guy's Avatar
Quoted: 118 Post(s)
Liked: 89
I own a DMR-EH67, (similar to the 57) and it works fine for my purposes. I subscribe to DirecTV and record everything to my DVR. For what I want to save, I play the DVR into my DVD recorder's had drive, and then dub it to -R media. This has been working for me, and I am quite happy with the process. The box says it had a region, but the people at world-import hacked it to all region, works fine so far. I assume it would work with one of those digital converter boxes, but the guide probably wouldn't work. With DirecTV, I never use the guide anyway, so it doesn't matter to me.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #9 of 12 Old 08-02-2008, 02:32 AM - Thread Starter
igreg's Avatar
Quoted: 270 Post(s)
Liked: 47
Cool. Can you record directly from satellite to -R media also? Thanks.
igreg is offline
post #10 of 12 Old 08-11-2008, 01:04 PM
ashiq88's Avatar
ashiq88 is offline
post #11 of 12 Old 08-11-2008, 01:06 PM
Rammitinski's Avatar
Originally Posted by ashiq88 View Post
but unless you can find a spec that says it has a NTSC or, more important for U.S., an ATSC, tuner..
It definitely does not have either.
It can record from a cable, satellite, or OTA digital or analog tuner of any sort in the US through a line input.
(I think that link you posted there needs to be removed, too.)
Rammitinski is offline
post #12 of 12 Old 08-11-2008, 02:07 PM
The foreign Pioneers do have an NTSC-M tuner, which can be used here.
