Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3576H? - Page 88 - AVS Forum | Home Theater Discussions And Reviews
post #2611 of 3505 Old 11-11-2009, 10:42 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
You are forgetting the other obvious (and cheaper) route. Go buy a $50 Toshiba DVD player for your Magnavox recorded disks that won't play on the Oppo and save the Oppo for commercial disks and PC burns.
No, I didn't forget the option of replacing the Oppo. I just didn't want to go that route at this point.
s it stated anywhere that the choppiness does or does not occur when the DVD is played back on the same 2160 it was recorded on?
It wasn't mentioned. No, there is no problem playing back on it's own drive.
hook up a DVD recorder that is known to produce readable DVDs on the Oppo/PC by component output and try that
I don't have access to another stand alone recorder.
make sure that ALL the exposed 'mounting' screws are tight, and that would include the 'dock' for the DVD unit and the HDD unit. And also, get some good hard rubber feet on the bottom of the deck! Vibrations are murder to DVD Burning.....sometimes
I only opened up one recorder. I didn't notice any 'looseness' to the optical drive. The problem exists on both of the recorders, so I'm reasonably sure it's not that.
BTW, I would use soft rubber feet to absorb vibrations, not hard.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #2612 of 3505 Old 11-11-2009, 11:41 AM
JDMoose's Avatar
Originally Posted by wajo View Post
Not only is it relatively easy for almost anyone to replace the HDD, but you could externalize it with an enclosure and toaster and have a HDD farm. Drives would be portable, "instantly" playable, etc.
See this help file for lots of info on that and esp. check the "Pioneers..." section, #5 for the external drives.
Thanks. Does the 2160 format the new HDD also? Would I be able to install one larger than the 160 GB?
JDMoose is offline
post #2613 of 3505 Old 11-11-2009, 11:53 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Yes and Yes. All that is in the link I gave. See "Pioneers..." section for upgrades already done.
7558037 is offline
post #2614 of 3505 Old 11-11-2009, 12:00 PM
JDMoose's Avatar
Thanks . I read the article after I posted the message. DOH! So it looks like if I order a newer 2160 I will be getting a SATA drive according to the post.
JDMoose is offline
post #2615 of 3505 Old 11-11-2009, 12:06 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
If you order a new one from Walmart, almost assuredly be a "A".
J&R is getting 100 more refurbs in 1-2 weeks for $160. Many members have bought these and they've been excellent. They also MAY be "A" units but their 1st batch were 2008 originals with PATA drives. 2nd batch of refurbs were all "A". I believe they may have sold out the supply of originals, but no guarantee, I guess... I'd count on "A" units also from J&R unless we hear otherwise from 1st buyer???
7558037 is offline
post #2616 of 3505 Old 11-11-2009, 03:59 PM
vabraxas's Avatar
Forgive me if I missed the info in this thread...
Is there a list of the differences between the H2160MW9 versus H2160MW9A ? Can someone point me to it or share it?
Also, have the refurbs from J&R been reliable? If any failed, what was the specific failure(s)? I'm considering ordering a J&R refurb, and would greatly appreciation the info.
Thanks in advance!
vabraxas is offline
post #2617 of 3505 Old 11-11-2009, 04:16 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
This section of a help file has a list of differences, with the 2160 and 2160A lumped in the right column Basically, the "A" has a SATA vs PATA, HDMI Control, a Yes/No Dialog to stop a recording.
The J&R refurbs have been excellent... many people are surprised by their NEW look! If their next batch of refurbs is as good as the past two batches, you'll be pleased I think.
7558037 is offline
post #2618 of 3505 Old 11-11-2009, 04:30 PM
Busey's Avatar
Just wanted to start by saying thank you to all that contributed to this thread. It's nice to have a reference point (w/ pictures & diagrams) when you are getting started. Furthermore, the suggestions and detail of posts have been extremely helpful.
I have a few questions, but I thought it would be best to tell you why I recently purchased the 2160A. Currently, I have two modded original Xbox's and an Xbox360 that are networked (locally) with a 3 TB NAS. About a month ago, I pulled my HTPC (myth) out of the network because of IR Blaster issues. Initially both the NAS and the HTPC were my storage/archiving spots for my video files. However, the primary purpose of the HTPC was recording TV and I was looking for a good alternative. As a sidenote, the best replacement for the HTPC would have been a networkable DVR, but I couldn't find one.
So, the route I'm going to take (unless a better way is suggested) is to archive on DVD then rip for network usage. I'll be recording quite a few basketball games and the occasional movie. My best available feeds from STB (sat) are S-Video and composite audio. Since the Magnavox will be connected to "extra" composite ports on the TV and I'll be manually recording, scheduling timers are not an issue.....plus a blaster is something I don't wish to deal with again.
As for sporting events, what recording mode do you suggest? It seems like quality/framerate could play a big factor in regards to choppiness/pixelation. Also, what is a good chapter setting for such recordings?
This is a little outside the scope of this thread: Currently I can stream ISO/wmv/avi files w/ the modified Xbox's, but the 360 can only handle a properly encoded wmv/avi(divx/xvid/mp4). Could anyone suggest a good format which would be compatible with all these machines?
After a few minor glitches, the magnavox seems to be performing like a champ. I must say I am very impressed with it's capabilities and the quality of video (while testing). Since I've done a little work on the original Xbox's and built quite a few PCs, the hard drive upgrade wasn't too intimidating. Actually, one of the first things I did was rip out the 160 GB drive and replaced it with a 500 GB. Goodbye Warranty.
Busey is offline
post #2619 of 3505 Old 11-11-2009, 04:40 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Here's a help file on the subject of recording sports that might help. Set chapters no closer than 10-minutes, the default.
Unfortunately, the 2160A doesn't do DivX, which is generally the only "other" video format besides MPEG-2 most DVDRs can play. The predecessor Philips 3575 and 3576 can play DivX and Xvid, but they didn't carry that over to the Mags.
You might have seen the "Pioneers..." section of the HDD upgrade help file here? I wonder if you'd consider posting some details of your upgrade that others might be able to learn from, like some of those in the linked section. If you do, I'll post a summary in the Pioneers section with a link to your upgrade post.
7558037 is offline
post #2620 of 3505 Old 11-11-2009, 06:13 PM
vabraxas's Avatar
....Since I've done a little work on the original Xbox's and built quite a few PCs, the hard drive upgrade wasn't too intimidating. Actually, one of the first things I did was rip out the 160 GB drive and replaced it with a 500 GB. Goodbye Warranty.
Thanks for the insights!
Can you provide more details on the HDD upgrade?
Which brand/model of HDD did you use? Simple swap? Any fiddling or hack required? Thanks in advance!
vabraxas is offline
post #2621 of 3505 Old 11-11-2009, 06:53 PM
Busey's Avatar
The upgrade wasn't too tough. Remember to format the drive. Here are the specific details that both you and wajo asked for:
Installing/Upgrading 2160A to 500G w/ HDP725050GLA360 (Hitachi Desktar)
Some extra Precautions:
1. It's always good to wipedown/clean the area you will be working on before you start.
2. Try to work in a low/no static area. It is also a good idea to touch the case BEFORE touching anything inside it (in order to discharge any existing static on your body).
Warning:
1. By removing original drive, you will not be able to access existing information/data stored on it (recordings, etc). However, if you choose to re-install the drive, the information/data should still be in tact.
2. Opening up this unit will void the warranty.
Instructions:
1. Unplug the 2160A for at least 10 minutes
2. Remove case (cover) screws: There will be 5 to remove from the back, and 2 to remove from the side
3. Pull outer case (cover) toward the back of the unit to remove it.
4. Gently pull away the data cable that is taped to the top of the hard drive. (You just want to temporarily remove it from the TOP of the drive).
At this point, leave all cable connections alone. Take a look at the hardrive connection. Notice that it is NOT connected to standard SATA cable, but rather to an adapter.
5. Remove the drive bracket screws (3 screws from mainboard)
6. Lift up drive bracket and remove electrical tape (located on bottom of bracket, holding adapter and bracket together)
7. Disconnect SATA ADAPTER (NOT CABLES) from original drive.
8. Unscrew drive and replace with new drive. (side note: these screws can be kind of tough to get out) Use original screws to attach new drive to bracket.
9. Attach SATA ADAPTER to new drive. Use electrical tape to fasten to bracket (as originally done) to hold it in place.
10. Set drive bracket back on mainboard and fasten it using the 3 original screws.
11. Press the data cable (from step 4) onto new drive (it should still be sticky enough to hold in place)
12. Replace original cover and screws.
Power on 2160A and use the SKIP 079 method to test the hdd cable connections. If everything is okay, press the OK button to format your new drive. (side note: "SKIP" is labelled as "V. SKIP" on remote control). Once formatted (assuming you turned your unit back on), press HDD and record a small clip of anything (10 sec will do). This will initialize/activate the drive (so that the HDD menu shows up). Enjoy!
Busey is offline
post #2622 of 3505 Old 11-12-2009, 01:03 AM
stump69's Avatar
Originally Posted by SteelTownGuy View Post
I love that some people refuse to get scammed like this. I've thought, for a long time, text spammers must be encouraged by cell phone providers (although they'd never admit it publicly). I'll bet over a million dollars a month or more gets siphoned away from people's accounts due to this behavior. Sure, they have to "put up" with the few people like Kelson that demand a credit, but overall its a nice supplemental income for them in these tough economic times.
I use about 60 - 100 minutes per month on my phone, so I have a T mobile prepaid account. A 1000 minute refill card will last me a year, so I pay an effective rate of $8.33/mo. Seems reasonable, so what's my gripe? Within a couple of days of activating my phone, I started receiving spam. Then I learned you get charged for text messages whether you open them or not. I went to the local store to have them block all text messages...they said that "feature" is not available on prepaid phones. How convenient! If there was some way to buy a phone today that was not text enabled, I'd buy it. I'm pretty sure they no longer exist.
Actually, they do. The Jitterbug phone (aka fogey fone) has no camera, no email, no texting function and it even has a real DIAL TONE. My wife and I could no longer read the buttons or screens on our TracFones so we went with Jitterbug.
stump69 is offline
post #2623 of 3505 Old 11-12-2009, 06:38 AM
SteelTownGuy's Avatar
$147 for the phone? Wow. I paid $30 for a Moto V195s. Not fancy by any means, but reception is excellent. I do like to use its calculator when shopping. Something tells me the Jitterbug doesn't have a calculator.
I'm kind of shocked our senior citizens are willing to part with that much scratch up front. Their rates are 20 - 30 cents per minute for their "cheap" plans, too. Not good. I'm more of a prepaid guy, anyway. I don't have to worry about monthly bills or expired minutes. Oh well...guess I'll put up with the T mobile scam until something better comes along. Thanks, though.
SteelTownGuy is offline
post #2624 of 3505 Old 11-12-2009, 01:47 PM
Busey's Avatar
That is a very well written, thorough walk-through/explanation of things wajo. Thanks for posting the link. Although I may need the "dummies guide" version.
I wonder how long college bb games are with all commercials/half-time cut out. It would be great to record in all HQ, though I highly doubt the full recording would fit on DVD. One thing I noticed with the HTPC (using PVR-150) was the wider the shot the worse the quality and the smaller the players the higher the distortion of picture/movement. Similar to what stated in the linked post about the football field.
I'll have to look your post over again to figure out a good way to do things. Thanks again for the tips.
Busey is offline
post #2625 of 3505 Old 11-13-2009, 01:53 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
I revised the SKIP 079 help file to clean up the recommended and alternate HDD tables, which were a "mess" only cuz they were relatively old.
With the recent Pioneer stories of 2160A upgrades, I noticed their original HDD's were "SLA" SATA models, not the "GLA" SATA models I listed based on the original 2160 PATA's being GLAT models.
In checking the spec differences, only notable things were lower Idle Watts for SLA and avg seek time almost half for the SLA vs the GLA (8 vs 14). One other BIG difference is in the spec for RELIABILITY: GLA = 50,000 start/stop cycles, SLA = 300,000 "load/unload" cycles (new term for start/stop, I guess)!
Anyway, now I think it's clearer and more specific to each model, with alternates to choose from, notes consolidated below the tables, etc., etc.
Some people obviously used the old charts for their 2160A's cuz they installed GLA models, which is fine, but now there's a table of the original model used in the 2160A's.
7558037 is offline
post #2626 of 3505 Old 11-13-2009, 06:00 PM
Busey's Avatar
Newegg is still sold out of the "GLA" and it looks like the "SLA" is not even available on the market. I did a few searches and couldn't find it. Going by these specs, it appears the SLA can handle more mileage. It's good to know that Funai is packaging a more reliable drive. I guess you have to weigh the capacity factor with the reliability factor and make your decision.
Busey is offline
post #2627 of 3505 Old 11-13-2009, 06:47 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
I found many sources for the SLA, but it gave me pause... my favorite site, NewEgg has some reviews that are NOT good. Price is good for a 160GB, tho, $38.99.
Here's another 160GB at $47.83.
I'm wondering if the GLA's might be better and maybe I should remove my "Recommended" notation in the tables?
Anyone know anything about these SLA's or can comment on whether they should be recommended, even tho they're OEM?
EDIT: I changed my "Recommended" to "OEM"... a political solution! Also found a review of 250GB SLA by 10 users that were excellent!
7558037 is offline
post #2628 of 3505 Old 11-13-2009, 09:33 PM
Busey's Avatar
To be honest, I didn't check the other capacity drives. I just did some searches for the 500G. Looking over things again, I may have searched for the wrong model number. DOH!! (For the SLA) Yeah, those reviews will not inspire too many customers to place orders.
As far as the GLA drive, time will tell. I'll be sure to post details if issues arise.
On the sports topic: I just recorded and edited the first game. Where is the WIN button on the remote control!!!!???? Joking. At SP, after editing, the game was a little over 3.3 gigs and ran slightly past 1 hr 1/2. There will be absolutely no way to record in HQ and fit on one disk (barring some real hardcore editing). However, since I'm using S-Video/composite audio this probably isn't that big of deal
Busey is offline
post #2629 of 3505 Old 11-13-2009, 10:09 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
On the GLA vs SLA, I changed my "Recommended" to just "OEM" to be more "noncommittal"
However, I did find other reviews of the OEM SLA's that were outstanding, like over 4 stars from 10 people, etc., so who knows. I think my new wording covers all the bases now for people looking for info on which drives to use, including a link to a nice Hitachi Comparison page where you can compare all the Deskstar drives.
On your game (basketball I assume?), if your edited version came out at 3.3GB for 1.5 hrs, HQ is out if you want to dub to 1 DVD, however, I think that edited time would work out to 2-hrs with commercials in? If so, you could still rec at SP and HSD to one disc without any editing, which might be OK when you don't have time or inclination to edit? You could go to 2:10:00 at SP with no editing and still HSD to one disc.
7558037 is offline
post #2630 of 3505 Old 11-14-2009, 11:59 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
For HDD upgraders, I've added a note in the Pioneers Section of the SKIP 079 HDD upgrade help file, under #5 Pioneer AUSKCK, this note:
"For an external farm, you might consider Hitachi Travelstar 7K500 2.5" drives made for laptops, which use MUCH less power than 3.5" Deskstars... 0.69-1.0W idle and 1.8W operating... amazing, to say the least! If you go this route, make sure you get a "Toaster" (hard disk dock) that fits both 2.5" and 3.5" drive, like those shown on this TigerDirect web page.
"The Travelstar *could* be used internally if you found a way to hold it in place since it's much smaller than the Deskstars. Dimensions (mm): Deskstar = 26.1 x 101.6 x 147... Travelstar = 9.5 x 70 x 100."
Auskck used a Travelstar 5K500.B HTS545050B9A300 (0A57915) 500GB 5400 RPM (externally I think) and proved it worked.
7558037 is offline
post #2631 of 3505 Old 11-14-2009, 01:18 PM
JDMoose's Avatar
Do you have to use a proprietory 160GB Hitachi HDD for a replacement in the 2160 or can you use any brand? I've had really good luck with WD in my PC's. Also aren't the newer 2160 SATA drives?
JDMoose is offline
post #2632 of 3505 Old 11-14-2009, 01:33 PM
sydyen's Avatar
2.5" drives can be used internally.
Any drive will be fine, just be wary of power demands on higher capacity. Since you like WD, go for the 3.5" greens.
The WD Scorpio Blue 500GB notebook SATA drives work fine internally. A riser was needed because the PATA/SATA adapter clearance required mounting upside down. Screwed a 5/8" wood riser (about 2" x 3") to the mounting plate and velcroed the 2.5" to that.
The 2.5" internal is cooler, quieter, and uses less power than the 3.5" but is a more expensive solution. My experience with consumer electronics power supplies is why spending the extra seemed worthwhile.
sydyen is offline
post #2633 of 3505 Old 11-14-2009, 01:36 PM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Check out the Tables (I-V) here for OEM and some alternate drives for each model, plus read the next "Notes..." section which mentions WD drives.
7558037 is offline
post #2634 of 3505 Old 11-15-2009, 10:35 AM
Davidjojo's Avatar
Just a quick note off subject for you OTA viewers. Check this out! It's the Echostar TR50 available at Sears as the DTVPal DVR. Looks like the ticket for OTA viewers. It records in SD or HD and has a TV schedule. NO FEES!
BTW I've had few problems with my H2160WV9. Any questions/problems I've had have been solved by coming here.
Thank you.
Davidjojo is offline
post #2635 of 3505 Old 11-15-2009, 12:11 PM
jjeff's Avatar
Quoted: 773 Post(s)
Liked: 270
For anyone thinking about the Pal, you should first read this thread and maybe this long thread. It's definitely a buyer beware product IMO but buying from Sears protects you a little bit if you don't like it.
jjeff is offline
post #2636 of 3505 Old 11-16-2009, 05:29 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
The list of negatives makes this look problem free. You loose signal for a few seconds and the whole recording gets dumped. How dumb is that?
On another note, it is appearing by using 4X RW media (minus or plus), this recording problem (notice I said recording, not playback since it isn't only on one player where the problems shows), seems to have been reduced to the first second or two of playback. Within two seconds, the playback will 'lock up' correctly, playing the video without any 'hiccups'. I had some store brand plus and minus RWs' that I decided to try and after viewing a few of them for only a couple of minutes, the studdering playback clears up after a second or two. Though, if you FF or skip ahead and then resume playback, it still takes a second or two to regain sync again.
Question is, is it because there are RWs', or is it because they are only 4x?
post #2637 of 3505 Old 11-16-2009, 05:40 AM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
Separate question;
I do NOT have the clock set on the recorder. The listings for recordings on the HDD do not show the time & date. But, on the burned DVD, there is a default date of Jan 1 08 showing. Is there any way to prevent this?
post #2638 of 3505 Old 11-16-2009, 07:25 PM
pm3839's Avatar
Originally Posted by Davidjojo View Post
.....BTW 'I've had few problems with my H2160WV9. Any questions/problems I've had have been solved by coming here. Thank you.
please tell us what problems u had....and what solved them....
*** its high time to go back to OTA antennas and CANCEL our cable/satellite pay tv services! their greed is totally & insanely out of control! ***
pm3839 is offline
post #2639 of 3505 Old 11-16-2009, 10:05 PM
vrkanti's Avatar
update on my 2160A.
Before returning i wanted to try another unit from wal-mart. wal-mart site-to-store took 15 days to deliver. I hooked up wal-mart unit, it works same as J&R unit. no surprise there. Few channels received as scrambled signal, here is my comcast channel lineup http://www.silicondust.com/hdhomerun...lineup_1119627, all are recieved by 3576H but not by 2160A.
I returned wal-mart unit, J&R customer service is great. got free return shipping label. if anyone want this unit in bayarea, want to pickup, PM me.
vrkanti is offline
post #2640 of 3505 Old 11-17-2009, 04:52 PM
JDMoose's Avatar
I just wanted to thank everyone for their help and advice on the Maggie 2160. I ordered it today, for Christmas for my wife, from Walmart with the free shipping to the store for pickup. I received an email saying it will arrive at the store between December 1-4. So if anyone is going to order one for Christmas I would recommend ordering it now. I'm just wondering when the warranty will start? Will it be the order date, today, or the day I pick it up at the store? The reason I am having it shipped to the store is just in case it arrives damaged. So after Christmas I'm sure I will have more questions for the forum.
JDMoose is offline
Closed Thread DVD Recorders (Standard Def)
