Can Anyone Help Me With MY Panasonic DMR-T3040? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-18-2008, 10:56 AM - Thread Starter
Anaheim's Avatar
The problem I'm experiencing with my Panasonic DMR-T3040 recorder is the aspect ratio when I burn a DVD.
I want my recorder to record my programs in 720 X 480. HOWEVER when I record the programs on LP speed and EP speed I get other types of aspect ratios. When I record on LP speed the aspect ratio is 352 X 480 and when I record on EP speed the aspect ratio is 352 X 240.
I thought this problem would be solved if I changed the Hybrid VBR Resolution from Automatic to Fixed but when I do that the aspect ratio results are the same. Any help would be greatly appreciated.
Anaheim is offline
post #2 of 3 Old 12-18-2008, 11:56 AM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
For those unfamiliar with this poster's Panasonic here is a February 2003 review:
http://digitalcontentproducer.com/vi...onic_dmrt_dvd/
I hope that someone familiar with this model will come forward with the sought-after information.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #3 of 3 Old 12-18-2008, 01:12 PM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Never heard of that one before. Sounds like it's basically a industrial version of the old HS2 Panny. I found this one thread in the archives.
http://archive.avsforum.com/avs-vb/s...ighlight=t3040
AFAIK the older Pannys like this one dropped the resolution on speeds above SP. I think Kelson knows the specifics but I didn't think it was as drastic as 352 X 480 in LP, but then again this is one of the first Pannys.
jjeff is offline
