No power down with Dish 722 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-21-2009, 11:17 AM - Thread Starter
JC_VT's Avatar
I recently got a Dish Network 722, but found that when turned off there was still either a fan or hard drive operating, making noise and generating some heat. This is when it is totally off, not recording either. After a few weeks a had Dish replace that, but the replacement is doing exactly the same thing. If this were my computer I would say the hard drive is not sleeping fully. Any one else experience this, or have any advice? I can live with it so long as it is not going to prematurely kill the 722.
JC_VT is offline
post #2 of 5 Old 04-21-2009, 11:53 AM
jjeff's Avatar
Quoted: 701 Post(s)
Liked: 247
I'm not familiar with your exact STB but if it's a DVR I believe basically all DVRs record to a live buffer and never shut down. IMO it's a big waste of electricity not to mention HDD life. Of course some people believe leaving a HDD ON all the time is easier on it than having it shut down.
I've read articles that say DVRs are about the biggest vampire in the average home. A vampire is something that draws power even when not in use. Many electronic devices never really turn off, unplugging is your only choice, but not a very good one for DVRs.
The article I read said something like, if we could get rid of all the vampires in the US we could eliminate 3 power plants. Again for some things it's not practical to unplug them. I don't think they were talking about things like clocks but rather things that are turned OFF but really aren't.
jjeff is offline
post #3 of 5 Old 04-21-2009, 12:37 PM - Thread Starter
JC_VT's Avatar
jjeff could well be right about that being normal behavior. As an experiment I pulled the power switch, and while it definitely was off then, when I plugged it back in the 722 had to do the satellite search again to upload the programming, which takes several minutes.
JC_VT is offline
post #4 of 5 Old 04-21-2009, 12:49 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
These time-shifting devices are discussed in more detail in this forum:
http://www.avsforum.com/avs-vb/forum...ysprune=7&f=42
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #5 of 5 Old 04-21-2009, 02:25 PM
Primestar31's Avatar
Quoted: 73 Post(s)
Liked: 45
The Dish VIP722 dvr NEVER shuts off. It only goes to a screen-saver mode when you hit the off button. That's NORMAL operating procedure for a dvr. If it completely shut off, it could never record your shows when you want.
I have owned a VIP622 (slightly older model) for several years, so I know this first hand. When it goes to screen-saver mode, it only saves about 1 watt of power. So, if you want a receiver you can turn completely OFF, you will have to go to a NON dvr model.
Primestar31 is offline
