Best DVD Media for Recording - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 08-20-2009, 05:10 PM
yonder's Avatar
That's what I figured. that the Valueline disks are TY seconds. I just bought some 8X Premiums in Calgary today, but the last time I was there for disks, they only had 16Xs and Valuelines in stock. I bought some of the latter, 'cause it was for recording F1 races off my DVDR for a friend, nothing of utmost archival importance. It never occured to me before, but I'm going to scan those disks after burning, see how they do.
yonder is offline
Old 08-20-2009, 05:15 PM
i86time's Avatar
I'm about 120 discs in on my most recent TY value 16x (Linkyo branded) DVD-R without any coasters used on my Panny DMR-EH75V and computer DVD burners.
i86time is offline
Old 08-20-2009, 05:35 PM
CitiBear's Avatar
Quoted: 103 Post(s)
Liked: 91
Many, many people use the Value Line product without complaint, and as I said TY "rejects" are better than other mfrs "primo" media. Now and then vendors do offer ridiculously cheap deals on the Value Line, in which case they can be a good choice for lower-priority burns or giveaways. But the fact remains they are "seconds", and since the entire point of bothering with TY at all is for its superior quality, why trifle with seconds? For important or archival burns, I'll always take the additional insurance of the "premium" media.
The quality difference between "value line" and "premium" is minimal: like DigaDo said, TY is not in the business of making crap- they aim to be perfect, every time. The "rejects" fail TYs very tough internal standards but would probably pass at CMC or Ritek without a second glance. The people most likely to run into trouble with the "value line" are those like myself with older recorders that now need 8x media to burn successfully: there have been many reports of 16x TY being mixed in with the 8x TY "value line" packages. If you absolutely must have 8x, and find out too late that you got 16x, you're screwed because you won't be able to burn it. So I guess the best advice is, if your recorder is new or you're using a PC, and the "value line" price is WAY cheaper than the premium, it can be a good deal. Otherwise, stick to the premium.
CitiBear is offline
Old 04-02-2013, 03:52 PM
SuicideBlonde's Avatar
I decided to go with the Verbatim 16x because someone here recommended it but, my system only lists Verbatim DVD+R/-R 8x. So, does that mean I can't use the 16x? If not, does it really make a difference anyway?
SuicideBlonde is offline
Old 04-02-2013, 04:17 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
You can use it. Your system will just burn it at 8X and no faster.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 04-02-2013, 06:20 PM
Old 04-02-2013, 07:29 PM
kjbawc's Avatar
If you're using Verbatim discs, make sure they are Verbatim AZO, or Verbatim Datalife. Those are the good ones. Most B&M stores carry Verbatim Life these days, and they are junk.
kjbawc is offline
Old 04-03-2013, 12:11 AM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
The Life Series (CMC) "landfill grade" is seen at the left and the AZO Series (MCC) good quality media is seen at the right. Notice that the cartridge points to the "AZO" logo. DVD+R package wrapping will be a different colour.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
Old 04-03-2013, 08:35 AM
tomwil's Avatar
Liked: 26
Except that the newer packaging removes the AZO logo and uses larger AZO letters instead.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
