Panasonic ES15 - Number of Hours? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By DigaDo
Old 09-12-2009, 02:23 PM - Thread Starter
WaldorfSalad's Avatar
Is there a way to check the number of hours on a Panasonic ES-15? I bought one on eBay and the seller claimed it was an open box item and not used but I'm not so sure.
WaldorfSalad is offline
Old 09-12-2009, 04:44 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Yes, in Service Mode:
1. To enter Service Mode power the machine off. Then on the front panel press REC, CH UP and OPEN/Close simultaneously for five seconds.
2. To display the Laser Used Time press 4, then 1.
3. To display the Accumulated Working Time press 6, then 1.
4. To exit Service Mode Press the power button on the front panel or remote control.
Do not experiment while in Service Mode.
ClearToLand likes this.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
