Need universal remote for Philips 3575 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-03-2010, 07:57 PM - Thread Starter
scarborv's Avatar
Hi,
My Philips 3575 remote has died. Can someone suggest a universal remote with decent size buttons under $100 and what is the code for the 3575?
I have a Philips PM435 universal remote that I tried but never could figure out the code for the 3575 - could be user error.
My tv is a Samsung LTP266W.
Also, what type of device should I select when programming the remote - it's mainly to use for recording and playing from the hard drive?
scarborv is offline
post #2 of 16 Old 01-04-2010, 10:41 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
The RCA RCRP05B ($20 at best buy) controls the philips 3575 using DVD code 1340.Here are all the codes:
Code:
Code:
0                        00018
1                        00010
2                       00034
3                        00026
4                       00242
5                        00234
6                        00002
7                        00250
8                        00082
9                       00074
channel up               00194
channel down             00186
power [standby on]       00050
tv/hdtv                   00047
up arrow                  00208
down arrow                00200
left arrow               00224
right arrow              00216
select [ok]              00176
play                     00051
pause                    00147
rew                      00075
fwd                      00083
stop                     00139
rec                      00123
Back (Prev Menu Screen)  00022
Clear                    00008
. Confirm (Decimal)      00054
DVD                      00038
Disc Menu                00132
Dubbing                  00079
Dubbing (Direct)         00102
Eject                    00232
HDD                      00071
HDMI                     00095
Info                     00058
Next Track               00019
Pause Live TV            00087
Prev Track               00011
Rapid Play               00180
Repeat                   00170
Replay                   00004
SP/EP [Rec Mode]         00110
Setup                    00030
Skip                     00012
Source                   00063
Subtitle                 00064
Timer                    00189
Title                    00076
Zoom                     00148
Skip+                    00019
Skip-                    00011
Display                  00058
Last_ch                  00158
Audio                    00064
Exit                     00022
Red                      00041
Blue                     00145
Green                    00065
Yellow                   00057
CAM                      00020
InputExternal            00063
Scart                    00024
USB                      00193
mdavej is offline
post #3 of 16 Old 01-07-2010, 08:20 PM - Thread Starter
scarborv's Avatar
Are there codes for "setup" and "title" while using the "hdd" function?
Thanks for the suggestions on the remotes!!
scarborv is offline
post #4 of 16 Old 01-08-2010, 10:47 AM
mdavej's Avatar
Liked: 940
Yes. I found a better list. See my corrected post above.
mdavej is offline
post #5 of 16 Old 01-09-2010, 10:32 AM - Thread Starter
scarborv's Avatar
I've purchased the RCA remote and programmed the DVD button with 1340 for the Philips. The 3575 will power on but the channel up and down buttons aren't functioning. I'm doing something wrong and can't figure out how to reprogram a key? Would you mind telling me the steps to reprogram a key?
00194 is channel up and 00186 is channel down?
I think I've figured it out:
Press the device key on the remote (i.e. dvd)
Press and hold setup until it blinks twice
Type 994
Press setup
Type 00186 (channel down code)
Press the channel down key
scarborv is offline
post #6 of 16 Old 01-09-2010, 04:47 PM
mdavej's Avatar
Liked: 940
Glad you figured it out. That's one way to do it, but you may have also been able to just turn off channel lock.
Use the same steps you did for fixing the channel buttons to reprogram any key.
mdavej is offline
post #7 of 16 Old 01-11-2010, 07:43 AM - Thread Starter
scarborv's Avatar
Turning off channel lock was the first thing I tried.
Thanks for the codes and your help! The remote is working perfectly now.
scarborv is offline
post #8 of 16 Old 01-11-2010, 06:41 PM
gastrof's Avatar
Quoted: 118 Post(s)
Why not just get the original remote?
http://www.remotes.com/remotes/servl...12632603977850
gastrof is offline
post #9 of 16 Old 01-12-2010, 01:14 PM
mdavej's Avatar
Liked: 940
Yes, you certainly can get the original, but it's 2x to 3x the price of a universal, and that's not counting the $8 shipping charge. The URC-8820N also works the same as the RCA I recommended and is only $15 on amazon with free shipping. If you're going to spend $60 on a remote, you may as well get something decent like a harmony, which also has every function from the original remote and has nice labels for them all on its LCD.
mdavej is offline
post #10 of 16 Old 01-13-2010, 08:54 AM
sgm26's Avatar
Originally Posted by scarborv View Post
Hi,
Recently I purchased a GE 24950 for under $15 at Target It contains a code that will control the Phillips but also has learning so you can teach it from your original if it is not completely fried.
sgm26 is offline
post #11 of 16 Old 01-17-2010, 09:36 PM
Flash Frwd's Avatar
Hi mdavej,
Will those codes work for the Philips 3455H/34 DVDR too?
Flash Frwd is offline
post #12 of 16 Old 01-18-2010, 07:35 AM
mdavej's Avatar
Liked: 940
Originally Posted by Flash Frwd View Post
Hi mdavej,
Yes, it looks like most of the codes are the same. Let me know which ones in particular you need and I'll post them.
mdavej is offline
post #13 of 16 Old 01-18-2010, 06:56 PM
Dartman's Avatar
Quoted: 14 Post(s)
The logitech remotes should work as well if you want a slightly better one.
My 880 was able to be programed online through the account I have on their web site and it can also be taught any missing commands while your online setting it up as well. I think most of their better remotes have the capability to be programed online just like the 880. You set up a free account then enter what device you want to control and it programs the remote through s USB cable, after that you can double check that everything works, rename things, move functions and buttons around, add new commands from the original remote if you have it, etc.
Dartman is offline
post #14 of 16 Old 01-19-2010, 01:02 AM
vicky86's Avatar
My Remote Control is good for my DVD. And I bought it about 3 months ago. The description sated it's compatible with most brands, including RCA, Thomson, Sony, JVC, Magnavox, Emerson, GE, Sanyo, Zenith, Philips, NEC, Panasonic, Hitachi, and Samsung. You could see if mine is also suitable for your Philips 3575.
vicky86 is offline
post #15 of 16 Old 01-19-2010, 09:02 AM
mdavej's Avatar
Liked: 940
I'm sure many, many universal remotes work with this philips. What's unique about the RCA is it can be programmed for absolutely every command without having to learn from the original, and it's cheap. None of the other's mentioned so far have both those attributes.
mdavej is offline
post #16 of 16 Old 10-29-2014, 09:24 AM
zzyzzx's Avatar
They are very expensive and they break. When they break it's a circuit board problem that can't be fixed either. I've never had any other remote break on me, or even need cleaning, but the Philips original remotes seem to break like mad.
I just got a Philips SRP5107/27 at walmart.com ($7, or $18 in the store) and it's a learning remote and it worked for me, but I had to program every button individually for the DVR. Wajo got it to work with the Funai code.
zzyzzx is offline
