Help with 16:9 Widescreen Recording - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 99 Old 01-09-2013, 07:41 PM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
W
Originally Posted by wajo View Post
Here's some info on both the Component and HDMI converter/filters.
Thanks Wajo
billmich is offline
post #92 of 99 Old 01-10-2013, 12:53 PM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
Do any of these lesser expensive conversion devices have a switch for the IRE issue?
Or does this "pal/NTSC" switch accomish the same thing?
billmich is offline
post #93 of 99 Old 01-10-2013, 12:53 PM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
billmich is offline
post #94 of 99 Old 01-28-2013, 09:28 AM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
Got the monoprice component to composite converter today at lunch
Can't wait to hook it up tonight, will give my quick take on it as well
billmich is offline
post #95 of 99 Old 01-28-2013, 10:57 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
A PAL/NTSC switch will not effect the black level, it's for switching between 50 and 60hz with the later used in our NTSC system.
jjeff is offline
post #96 of 99 Old 01-28-2013, 01:04 PM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
Thanks for the info
I will so am a-b comparison to see how much the IRE LEVEL difference looks to me
billmich is offline
post #97 of 99 Old 01-31-2013, 05:45 PM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
I guess I have an untrained eye, but the picture looked pretty good in my eyes
I was able to use the h-fill mode and the picture fills up my entire screen without the loss of quality that ZOOM mode does
Does the IRE difference make the picture lighter or darker now?
I give this product my full endorsement....
billmich is offline
post #98 of 99 Old 02-01-2013, 05:02 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Playing a commercial DVD on a international Panasonic and watching it through it's SD(composite or S-video) outputs it will be slightly dark.
Making a recording on a international Panasonic(from a standard +7.5 IRE N. American source(VCR, STB, DVR, etc.)) will look fine playing it back on the Panasonic(from it's SD outputs) but too light from it's HD(component and HDMI) outputs. It will also look a bit light if you take that DVD and play it in a standard N. American DVD player or computer.
It's kind of confusing but again the main point is playing DVDs made on a international(with a non darkened input) will produce DVDs with a IRE of +7.5 whereas they should be 0 IRE for black and that will look slightly light on standard DVD players.
As to your last point, I agree and if you can darken the input it makes it downright perfect cool.gif
jjeff is offline
post #99 of 99 Old 02-01-2013, 06:29 AM
billmich's Avatar
Quoted: 272 Post(s)
Liked: 60
I am using HDMI out from My EH55, the picture appears to look a tad darker, if Anything
billmich is offline
