Hard Disk File System investigation for the Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #61 of 217 Old 02-07-2011, 05:27 AM - Thread Starter
PeterTheGeek's Avatar
We need to figure out how the video is stored inside the AV001_0AV001_00.MPG file. I was thinking that there would be some links like this:
record in TI000_0TI000_00.IFO -> somewhere in TM001_0TM001_00.MAP -> somewhere in AV001_0AV001_00.MPG
So far I haven't be able to find any of the links. I don't think you will be able to get a good clip off the drive without finding where the segments live. As I found that the ratio between the MPG_SEG_MPG_SEGM.DAT file and AV001_0AV001_00.MPG file are changing with disk size. The segment lengths should get larger on the larger disk drives.
Pete, if you want to try looking through the directory entries in the TI000_0TI000_000_00.IFO files. That might help us figure out the links. I don't think we will get very far with the video file extraction until we can figure out this relationship. Some of it is definitely index array type thing. I know the TI000_0TI000_000_00.IFO looks like it is arranged that way anyway.
Example have array A. A[1] is first record, so if you see a A[200] you have to do:
Location of A[200] = (size of one record of A) * 200 + (A[1] location)
The indexing come in where you have a result from one array feed another array.
Ex. I is an index for A
A[I[5]]
It does appear that the TI000_0TI000_00.IFO is arranged this way for storing the titles and chapter headers. More about that later.
iBoard has a nice feature in it. If you highlight up to for bytes in the view mode down is the hex area. It will display the little-endian and big-endian numbers, up to four bytes at a time. This file format the Magnavox is using the little-endian.
PeterTheGeek is offline
post #62 of 217 Old 02-10-2011, 10:51 AM
profhat's Avatar
So, until now you have used successfully iBoard, and which other software?
profhat is offline
post #63 of 217 Old 02-12-2011, 07:52 AM - Thread Starter
iBoard, which runs on Windows, is what I've been using to see what is on the hard drive. It will copy blocks, write blocks as well as view and edit data right on the hard drive. It makes it easier to see what is on the drive. I would think there are other block hex editors for the Mac and Linux systems as well. I just haven't looked for any.
We are hoping to be able to figure out the file format used on the Magnavox units to be able to resize a file system for a drive upgrade. Also, other people would like to extract the video directly from hard disks.
post #64 of 217 Old 02-23-2011, 02:24 PM
profhat's Avatar
Thank you very much for your efforts, I'll keep checking for updates!
profhat is offline
post #65 of 217 Old 02-24-2011, 06:06 AM
timtofly's Avatar
It has been reported in the 3455 thread, that Ubanti can mount a 3455 drive and "read" it. See links to another forum/web site.
timtofly is offline
post #66 of 217 Old 02-27-2011, 05:56 AM - Thread Starter
Little busy right now so it might be a while before I get back to this investigation.
post #67 of 217 Old 03-09-2011, 05:04 PM
PeteMI's Avatar
Yeah I'm sort of sidetracked with some work projects at the moment...
I did give isobuster a go with the image I pulled off my 500gb hard drive with iBored...unfortunately what it seemed to do is detect a bunch of MPGs and the ocassional other filetypes in between...and when I extracted the MPEGs they all seemed ok and played fine in windows media player, and were all found 'in order of recording', but some files were detected as being JPGs or other types, and when I renamed them as MPEG files, they played fine as well..so something different was being detected by isobuster...something to disrupt it from thinking it was one huge mpeg with pointers, or thinking it was another file type altogether..
One other thing I noticed, was that the mpegs that were extracted had some unusual time cuts... it wasn't like a half hour show would be one MPEG..the end of one file and the beginning of another might be in the middle of a show...and if you put the two pieces together in a video editor like Sony Vegas, it wasn't just a smooth transition from one clip to the next - there was usually a half second gap or something else noticeable...so the whole process is interesting, but not exactly a solution unless you really wanted just a particular clip, were trying to rescue footage, etc. I still seem better off just extracting that one huge file...but am still searching.
Thanks for that link on the Philips discussions...that's what got me trying tis solutoin...but I'm just not sure if the person that tested using isobuster with their extracted Philips DVR hard drive data noticed 'many small files that could all be reassembled' like me....and actually tried to do this and found what I did...or if they just saw a bunch of files and said 'oh here it is, i just have to assemble them sometime' assuming it could all cleanly be dumped into Pinnacle to reassemble the parts they wanted...
Back to the drawing board
Pete
PeteMI is offline
post #68 of 217 Old 04-02-2011, 08:54 AM
profhat's Avatar
Thanks, I rly didn't know about that site!
profhat is offline
post #69 of 217 Old 05-27-2011, 03:01 PM
copperblade's Avatar
You might be able to use foremost on Linux to magically extract the files, if that's what you need. Just given the 7 blocks someone posted above, I got this using strings:
528 HDDFs 00.07
1536 0`8:
1541 #5:G<<br /> 1688 SYSCTR
1695 DF000_00.LST
1759 FB000_00.LST
1816 SYSCTR
1823 TR000_00.LST
1880 FONT_DAFONT_DAT.DAT
1944 BU_DVDFBU_DVDFS.DAT
2008 BU_LOG_BU_LOG_D.DAT
2072 VBI_DATVBI_DATA.DAT
2136 TI000_0TI000_00.IFO
2200 TM001_0TM001_00.MAP
2264 TC001_0TC001_00.CHP
2328 TM002_0TM002_00.MAP
2392 TC002_0TC002_00.CHP
2456 MPG_SEGMPG_SEGM.DAT
2520 AV001_0AV001_00.MPG
Since it would be impractical for someone to send me a 500 GB file with their entire disk image, if you have access to Linux and install foremost, try this:
foremost -o recovered -v disk.img
If that doesn't work you can try sleuthkit: http://www.sleuthkit.org/sleuthkit/desc.php
copperblade is offline
post #70 of 217 Old 05-28-2011, 08:20 AM - Thread Starter
Copperblade, thanks for the tips. Maybe Sleuthkit will help. I hope to find some time to work on this. This is what I do know.
There is no partition table, sector 0 is all 0s.
The format is setup in a way to do one thing and that is to store and edit videos. Some of the files have copies, apparently for keeping a working copy and an edit copy.
Some of the data is linked by position. This big problem is still how to jump from the .MAP files to the video stored in the .MPG file. I think if we can figure that out we can easily get the mapping from the VBI_DATVBI_DATA.DAT to the .MAP file. I think the .MAP file is stored in to sector blocks with the first sector pointing into the .MPG file just based on it's position in the .MAP file. So the first two sector block points to the first block in the .MGP file and the second two sector block points to the second block in the .MPG file and so on. Just a theory right now, I have not confirmed this yet.
post #71 of 217 Old 05-28-2011, 09:09 AM
Yeah partition tables are pretty meaningless when you're using the entire disk. I routinely make filesystems without partitions for my storage devices.
I was thinking about whether or not they're using the space as just a big caching area, or have some kind of filesystem underneath. Either way, I don't think there is any way for the data to be sequential. Maybe large parts of it are, but it can't be guaranteed. I don't think it can even be guaranteed that a single title will be on the disk in one big sequential chunk because that means after storing and deleting multiple times you will get fragmentation with useless space that eats up the drive. (Also since it lets you record on the fly, there's no way for it to know how much space on the disk it will need to reserve.)
I think the best way to figure this out is to start with a fresh, unused drive in one of these devices and make a snapshot of the device. Then make a snapshot after each of:
1) Record one title
2) Record a second title
3) Delete one title
4) Record a third title
That would be the systematic way to get enough information about the underlying method of storing the data. Maybe to make the process easier, you could pick a small drive and just make sure the contents have been zeroed a few times.
post #72 of 217 Old 05-29-2011, 06:01 AM - Thread Starter
I have been doing some of my testing on a 40 Gig drive. The information at the beginning takes up about 1 Gig, only two files changes with the filesystem size and that is the MPG_SEGMPG_SEGM.DAT file and the AV001_0AV001_00.MPG file. I believe the MPG_SEGMPG_SEGM.DAT file is a used / free hash table for the AV001_0AV001_00.MPG file. I currently have an image that I was looking at with three short 1 minuet videos on it. I didn't try deleting the second file before recording the third though. Hopefully I can look at this some this summer.
post #73 of 217 Old 06-06-2011, 12:41 PM
profhat's Avatar
Thanks copperblade for the idea!
Please, try!
profhat is offline
post #74 of 217 Old 06-30-2011, 05:56 PM
profhat's Avatar
I don't want to open a new thread, and since this one is related to HD's tests, will an SSD (Solid State Disk) work fine with a Magnavox? Maybe those devices help with the advance of this investigation.
profhat is offline
post #75 of 217 Old 07-02-2011, 06:59 AM - Thread Starter
I don't see why not. They do cost a lot more than a hard drive. But they are faster and lower power than even the notebook 2.5" drives. I put a 2.5" AV hard drive in my main 2160A.
post #76 of 217 Old 07-02-2011, 07:08 AM - Thread Starter
On the video extraction front. I have been looking at a lightly use drive image and have been able to extract most of the video that was stored on it. I still can't figure out how to go from the directory listing found in TI000_0TI000_00.IFO to the video in the AV001_0AV001_00.MPG file. I know the information should be in the TM001_0TM001_00.MAP and the TC001_0TC001_00.CHP. But I can't seem to connect the dots. I did decode the time length part of the directory listing that you see while looking at the titles.
Maybe I can find sometime soon and post what I have so far and someone else could connect the dots.
post #77 of 217 Old 08-28-2011, 10:57 AM
profhat's Avatar
Could you share that file? I'm rly interested to take this to the next level.
Thank you!
profhat is offline
post #78 of 217 Old 08-28-2011, 05:15 PM - Thread Starter
Could you share that file? I'm realy interested to take this to the next level.
Thank you!
I'll try compressing the entire 40 Gig hard drive. Since most of it is blank it is currently doing about 1000:1 ratio. I am guessing that it will be about 100 Meg. I put a link in a post to where it will be stored. A friend of mine has suggested a few places where I could place a big file to share.
The file will take over 4 hours to compress so I'll try to post earlier part of this week.
In my post through the thread I have what I have figured out so far. So you have that to start with.
post #79 of 217 Old 08-31-2011, 06:06 PM - Thread Starter
I posted the first 1.2 Gig of the hard drive to 242Meg zip file. This is the first time I used We Transfer. It is a neat service I hope they can keep it running. Anyway, the file will be deleted on September 13. Let me know if you need it posted after that date.
post #80 of 217 Old 08-31-2011, 06:25 PM - Thread Starter
Just to help out with the disk image I posted.
First, it still looks like the allocation units in the AV001_0AV001_00.MPG file is in 8 Megabyte increments, or 16384 sectors.
I have 7 saved titles on this image and I think they should all be in the section I posted. I have found 4 of them at the following sector numbers.
4.1 SLP start at sector number 2008029 and runs 16 Megabytes
5.1 EP start at sector number 2155485 and runs 24 Megabytes
5.2 LP start at sector number 2221021 and runs 24 Megabytes
11.1 SPP starts at sector number 2270173 and runs 24 Megabytes
I was able to save the MPGs out at those starting sector numbers and play them back on my computer. They are all about 1 minute videos, so not too long here.
I have the file mapping listed earlier but just in case, only the last two files vary with the disk size. This was on a 40 Gig drive so:
MPG_SEGMPG_SEGM.DAT starts at sector 2008025 and runs 4 sectors
AV001_0AV001_00.MPG starts at sector 2008029 and runs 76103680 sectors. The posted disk image has this file only partially there.
I believe the link from the title file TI000_0TI000_00.IFO, is in the TM001_0TM001_00.MAP file. I just can figure out the MAP file at all. Some with some knowledge of mpg file might be able to see what it is but I can't.
post #81 of 217 Old 08-31-2011, 09:20 PM
mrmazda's Avatar
Quoted: 162 Post(s)
Liked: 55
I was going to download that zip, but that URL is insane. There's no download link, or anything else except a requires Flash message.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is offline
post #82 of 217 Old 09-01-2011, 02:52 AM
Ken.F's Avatar
Quoted: 1723 Post(s)
Liked: 1546
One of those segments is part of a Roseanne episode. I saw the Magnavox info screen while playing it. Did you save that title from the auto record buffer?
Ken.F is offline
post #83 of 217 Old 09-10-2011, 05:05 PM - Thread Starter
Nope, that title was not saved. It is just what the auto record buffer had put in the .MOV file. I did list sector number in a previous post for four of the saved titles.
post #84 of 217 Old 09-10-2011, 05:08 PM - Thread Starter
We Transfer does use Adobe Flash Player. So you will need a browser with that loaded in it to have this work.
Ken.F got a copy downloaded.
post #85 of 217 Old 09-10-2011, 05:51 PM - Thread Starter
The title listings are found at sector 61235 and run for three sectors. On post 55 I have the record as much as I have decoded listed there.
Here is the list:
JAN/31/11 5:31PM 4.1 SL
JAN/31/11 5:32PM 5.1 EP
JAN/31/11 5:33PM 5.2 LP
JAN/31/11 5:34PM 11.1 SPP
JAN/31/11 5:35PM 11.2 SP
JAN/31/11 5:36PM 45.1 HQ
JAN/31/11 5:37PM 45.2 SLP
As in a earlier post, I listed where the 4.1, 5.1, 5.2 and 11.1 records live in the MOV file. The others should be there as well but I didn't find them.
post #86 of 217 Old 09-10-2011, 08:26 PM
mrmazda's Avatar
Quoted: 162 Post(s)
Liked: 55
Web browsers are web browsers, not downloaders. I only download with downloaders, so that all characteristics of the original that can be preserved are preserved, not the least of which is the timestamp indicating source's "creation" date instead of the download date, and so that recovery from drop point is easy and no prior bytes downloaded are wasted when a download connection breaks.
I keep 6 web browsers open most of the time. Only one is allowed Flash, and tabs with Flash in them that don't behave politely, which is most Flash using pages, get closed summarily.
Flash is a scourge on the web. http://www.useit.com/alertbox/designmistakes.html http://www.useit.com/alertbox/20021125.html
mrmazda is offline
post #87 of 217 Old 09-10-2011, 09:11 PM
Ken.F's Avatar
Liked: 1546
If it helps you any I found that VLC can play the img file as is.
Ken.F is offline
post #88 of 217 Old 09-25-2011, 11:48 AM
Trac's Avatar
We were OT in the main thread, so this is a double post.
Originally Posted by chili555 View Post
Can it be true that there is no partition table and no file format?
You're catching on. Proprietary set top boxes don't need PC compatibility. Indeed, their makers probably want the opposite in order to appease digital copyright holders.
And indeed, this subject is better kept to the hard disk file system investigation thread.
Good News/Bad News: The bad news will be posted in the HDFSI thread.
Every HDD I throw at the Funai are compatible as long as the "Delete Volume>Create New Volume" procedure is used with a 512 Allocation unit size.
The three file formats; NTFS, exFAT, and Fat32 are also compatible.
With Fat32, the prog Fat32Formatter was used with Delete partition.
***None of the HDDs have Advanced format technology, so I'm not sure if they will work.
________________________________
The Bad,
The Funai does not "format" the drives, the existing file system is used with what appears to be a small DOS OS installed on the front end, so only the Funai can see/read the content on the HDD.
After "formatting" the drives in the Funai, then connecting them back to a Windows PC, the original file system and volume name are retained, and the only visible content is an empty recycle bin.
In Ubuntu, when a drive can be seen/mounted, different commands(from my very limited understanding) would result in a DOS warning and Permission Denied.
Trac is offline
post #89 of 217 Old 09-25-2011, 02:57 PM
mrmazda's Avatar
Quoted: 162 Post(s)
Liked: 55
http://fm.no-ip.com/Big/p633HD1head.zip contains the first 2G from a Pioneer DVR-633 160G PATA HD, I think containing 239 titles, but possibly containing 118 titles.
http://fm.no-ip.com/Tmp/Hardware/Disk/p633HD1h256.zip contains the first 256 sectors from the same device.
It contains a PC compatible partition table with one partition of type A5, FreeBSD/386.
http://fm.no-ip.com/Tmp/Hardware/Disk/magn1head.bin is the first 8 sectors from my #1 2160A's original HD made 11 months ago before sending it in for service.
Note the absence of content in the MBR - IOW, no partition table, and no partitions.
http://fm.no-ip.com/Tmp/Hardware/Disk/m1D2H256.zip contains the first 256 sectors from the same device made this past July when there were 247 saved titles, at the time I installed a 320G HD in its place.
http://fm.no-ip.com/Big/m1D2dump.zip contains the first 2G from the same 160G SATA HD last used in July. It has never been subjected to writes by anything other than the 2160.
mrmazda is offline
post #90 of 217 Old 09-26-2011, 05:31 AM - Thread Starter
I have been blanking the hard drive will all 0s before starting so there wouldn't be any extra bits turn on that the DVR didn't do. The hard drive format they are using is their own and doesn't have a partition table or boot sector or any computer general file system on it. The drive is just for storing data.
I haven't pulled together the information into one spot but several of my post have information that I have decoded.
The header information at sector 4:
Post 6
The directory listing at sector 4 and 5:
Post 11
I have figured out what most of the file are for. Only two of them change with drive size and that is MPG_SEGMPG_SEGM.DAT and AV001_0AV001_00.MPG.
The titles are stored in TI000_0TI000_00.IFO. If you go in there you will see the titles. I have figured out some of these records but haven't gotten very far with it.
This is my first stab at the TI000_0TI000_00.IFO file data.
Post 55
I detail the two files that change size with the hard drive.
Post 60
I'll try to download the data you posted mrmazda and see what I find. I have most of the file uses figured out but not the bits in them.
I think the TM001_0TM001_00.MAP and TM002_0TM002_00.MAP have time indexes on them. Most of the data looks like this because it just increments going down a list. I haven't been able to figure out what the first 16 bytes means at all. I think that is where the secret is for mapping from the directory listing in the TI000_0TI000_00.IFO through the TM001_0TM001_00.MAP to the AV001_0AV001_00.MPG that stores the video.
I have extracted video from the AV001_0AV001_00.MPG
List of video found.
What is in the title listing.
I just save off the sectors I want and name it .mpg and then it plays just fine.
This file system used on the DVR is based on a 512 byte sector. I can see why the advanced sector format drive is a problem.
I attached my to files for the director listing and the MAP file.
The MPG files starts at sector 2008029.
MultiTitles TI000_0TI000_00.IFO.zip 0.822265625k . file
MultiTitles_TM001_0TM001_00.MAP.zip 453.8154296875k . file
File Type: zip MultiTitles TI000_0TI000_00.IFO.zip (842 Bytes, 62 views)
