Hard Disk File System investigation for the Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #211 of 217 Old 02-21-2017, 05:35 AM
Liked: 0
Format a replaced hdd MDR513H/F7.
Hi DVR Geniuses!
I am impressed by your knowledge base. I am having problems with my Magnavox DVR MDR513H/F7. I recently replaced its hdd after the original died. I found the identical HDD (size, modal, manufacturer, etc), and installed it after formatting it fat32. I get a error within the DVR saying can't record to it. I have a feeling the format is proprietary. Any suggestions? Thanks for your help!
Paradoxgrowth is offline
post #212 of 217 Old 02-21-2017, 05:56 AM
mrmazda's Avatar
Quoted: 116 Post(s)
Liked: 41
Originally Posted by Paradoxgrowth View Post
Hi DVR Geniuses!
FAT32 doesn't work. Use the proprietary setup procedure.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is offline
post #213 of 217 Old 02-21-2017, 07:03 AM
NOSTRADIMWIT's Avatar
Quoted: 20 Post(s)
Yup ... works like a charm. Seems to me I had a couple little glitches getting the Maggie 537 to recognize a new blank drive, but once it finds it, the rest is short and consistent.
PS ... currently have four 1tb drives in the rotation using the external dock ... only "problem" I've had is the drive occasionally disappears, but that's because of a cheapo cable ... wiggle that a bit and reboot, and it comes right up again. I did pick up a better cable, but of course, it's been working fine since. Go figure.
Life is a journey. Time is a river. The door is a jar ...
NOSTRADIMWIT is offline
post #214 of 217 Old 02-21-2017, 07:35 PM
Liked: 0
[quote=mrmazda;50929729]FAT32 doesn't work. Use
Wow thank you so much! That's so nice. My head was source from banging it against the wall!
Ps saw your rig. Rotating hdds! So jealous!
Thanks again guys
post #215 of 217 Old Yesterday, 11:52 AM
profhat's Avatar
Greetings!
So is there any news about how to rescue/undelete deleted tittles from our Magnavoxes?
As always, all of you make an awesome team.
Cheers.
profhat is offline
post #216 of 217 Old Yesterday, 12:10 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 196
Originally Posted by profhat View Post
Greetings!
Cheers.
While some solutions have been tried successfully... my help file is here but 1st 3 internal links don't work anymore... one user tried my suggestion for the cdroller app, which worked.
cdroller app
That's as much as I can tell you.
wajo is offline
post #217 of 217 Old Today, 03:26 PM - Thread Starter
PeterTheGeek's Avatar
Greetings!
Cheers.
I have not looked into that. I really don't have time to do so right now either.
You should look into the help Wajo pointed you to.
From what I've seen the directory entry will be totally blanked out. So the video would still be on the disk though but you won't be able to put them back together unless they were all in a row.
PeterTheGeek is online now
