Can i manually clean a DVD recorder laser with achol? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-01-2011, 09:37 AM - Thread Starter
cajunboyz's Avatar
Can I DVD recorder laser be cleaned with rubbing acohol safely???
cajunboyz is offline
post #2 of 3 Old 02-01-2011, 02:17 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Personally I wouldn't use a solvent on the lens, instead I'd use a fine bristled brush. A clean makeup brush works good. That said if your lens has something stuck to it(as apposed to the normal fine dust) I guess iso alcohol would be one of the gentlest of solvents you could use.
Truthfully I've never had a take apart laser cleaning fix anything that a cleaning disc didn't help. Actually cleaning discs usually don't help either but I've had them help a few times, but the times they didn't help I've tried the manual cleaning method which didn't help either.
jjeff is online now
post #3 of 3 Old 02-01-2011, 03:02 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
There are different cleaning procedures for different brands.
In the following thread I've given detailed cleaning information for DVD Drives found in Panasonic recorders:
http://www.avsforum.com/avs-vb/showt...8#post14479898
In the following post I've given detailed cleaning information for DVD Drives found in Funai manufactured recorders, Philips, Magnavox, Toshiba, Sylvania, Emerson, PYE, Symphonic, TruTech and others:
http://www.avsforum.com/avs-vb/showt...2#post19647592
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
