Video recorder Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-05-2011, 06:58 PM - Thread Starter
MasterMind555's Avatar
I recorded TV shows with an external hard drive ( Plugged on an Bell decoder ) And I want to transfer those shows to my computer, but when I plug it to my laptop, it detects it,but doesn't give the option to go in it, how do I bypass that? Thanks
MasterMind555 is offline
post #2 of 6 Old 02-07-2011, 10:55 AM
CitiBear's Avatar
Quoted: 102 Post(s)
Liked: 91
You can get more/better answers if you provide the make/model of laptop, make/model of portable HDD, and what software you use to view/edit the video files (have you done this before with no problems, or is this the first time you're trying to import video from the Bell/HDD)? What OS is running the laptop (Windows XP, Vista, 7, MacOSX, etc). Also, if you have antivirus software installed, let us know what brand/version as well.
CitiBear is offline
post #3 of 6 Old 02-12-2011, 08:26 AM - Thread Starter
Ehhh I never did this before, it's saved on a external hard drive, plugged on a Bell HD Decoder, and I use Windows 7. I use Avast! Antivirus, and I'm on a Toshiba Satelite, but it doesn't work more on my old computer that runs on Windows XP
post #4 of 6 Old 02-12-2011, 12:47 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Basically everything recorded by a DVR is protected by encryption(or a format not easily readable by a PC). You won't be able to read it on a computer
jjeff is online now
post #5 of 6 Old 02-16-2011, 09:45 AM - Thread Starter
No hax?
post #6 of 6 Old 02-16-2011, 01:11 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
It's possible but I doubt anyone in this sub forum would know. AVS does have a HDTV Recorders forum but I don't see much about Bell equipment, which I assume is Canadian?
Good luck
jjeff is online now
