Recorder with HDMI Inputs? Yes it exists - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #151 of 182 Old 04-29-2013, 05:53 AM
esdwa's Avatar
Originally Posted by hifiphones View Post
...As I understood the MTV7000 would be a better solution as it has less limitations on HDMI recordings?
The standard MTV7000 model is no longer manufactured and it was replaced with Mini model. The only difference between two is lack of component inputs in mini which does not matter if you plan to use two hdmi inputs. Everything else is the same including features as well as limitations. I use my mini's for several months now and they do perform excellent so far. Good luck.
esdwa is offline
post #152 of 182 Old 05-08-2013, 02:41 PM
Seeker47's Avatar
Originally Posted by Cyclone82
Interesting thing i found out today when i asked a ebay seller if he had any 'ViewHD' HDMI to component converters. Yes he still has them but will only sell via email and will not list them on ebay. They have also disapeared from Amazon. Seems like hes been told to remove them. These units are the same sort of thing as the HDfury. They must be really cracking down on anything that accepts a HDMI signal and ignores the copy protection.
So, you're saying the View-HD supply has dried up ? Good thing I got mine before they got scarce. I mentioned this in another thread, but some early reports were indicating that this little box
http://forum.videohelp.com/threads/334145-HDCP-strippers?p=2217543&viewfull=1#post2217543
worked and could be a game-changer . . . at least until they try to squelch it also. But my hope is that whatever Big Content tries to suppress, their efforts will amount to no better than a game of whack-a-mole, because other options will keep emerging.
Seeker47 is offline
post #153 of 182 Old 06-29-2013, 02:34 AM
hifiphones's Avatar
Got my MTV7000-Mini, awesome thing!
The only problem so far is that I cannot rename the sources?
I can rename Input 3 which is composite, but Input 1 and 2 which are HDMI cannot be renamed? Any ideas?
hifiphones is offline
post #154 of 182 Old 06-29-2013, 07:30 AM
esdwa's Avatar
Weird. Mine allows assigning name to each input including custom name.
It is available in Setup menu under this option
esdwa is offline
post #155 of 182 Old 06-30-2013, 05:15 AM
hifiphones's Avatar
Cheers, did mine also under setup but cannot select input 1 and 2. Do you have the newest firmware?
post #156 of 182 Old 06-30-2013, 06:22 AM
hifiphones's Avatar
Allright, after updating my firmware from 7.02 to 7.05 i found out that there was an input selected under nowTV and cableTV. After changing the input to "none" I was able to change the name smile.gif
post #157 of 182 Old 07-01-2013, 12:38 PM
profhat's Avatar
Congratulations! Do you buy it in the US?
profhat is offline
post #158 of 182 Old 07-02-2013, 04:14 AM
hifiphones's Avatar
No, got it from HK
post #159 of 182 Old 07-02-2013, 05:10 PM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
No, got it from HK
What I am interested in is exactly HOW you got it from HK, or more specifically, how we can get one?
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #160 of 182 Old 07-25-2013, 05:40 AM
hifiphones's Avatar
I got a mate in HK, who went into a local shop and bought it for me, then shipped to Europe.
One thing I have noticed is, when I am playing a recording a small "PLAY" sign appears on the LEFT top corner. Is this normal, or can be disabled somehow? Quite annoying when this sign appears every 1minute.
post #161 of 182 Old 07-25-2013, 11:02 AM
Quoted: 111 Post(s)
Liked: 86
I had a feeling your source was something like that. Not really a general source for the public, is it. Thanks for the information though.
Luke
post #162 of 182 Old 07-26-2013, 02:47 PM
profhat's Avatar
Hi guys, do you think that the new Google's CHROMECAST HDMI device will work with the MTV-7000 line?
profhat is offline
post #163 of 182 Old 08-02-2013, 03:44 PM
esdwa's Avatar
It can be turned off in Settings menu. Read manual or just browse on your device, you will find it.
esdwa is offline
post #164 of 182 Old 10-17-2013, 05:09 PM
TheFreeman's Avatar
Hi,
There is a newcomer in the HDMI recording field, check this indiegogo project: http://igg.me/at/wizarm/
Or video link here: http://www.youtube.com/watch?v=tcLuppUAkr4
Looks great !
TheFreeman is offline
post #165 of 182 Old 10-17-2013, 05:55 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Originally Posted by TheFreeman View Post
Hi,
Looks great !
Please stop spamming the threads with this.
If I see it one more time I'm going to report it.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #166 of 182 Old 01-20-2014, 09:32 AM
CoastRanger's Avatar
Kelson,  I saw your comment about the Wizarm device.  I wasn't able to figure your thoughts about it, except that you might not care for it.  Is it real or a sham?  Does it work as advertised?  Can you provide some skinny on the device?
CR
CoastRanger is offline
post #167 of 182 Old 01-20-2014, 10:38 PM
Clint S.'s Avatar
Quoted: 48 Post(s)
Liked: 0
How many tuners does that Wizarm device have? Doesn't say on the webpage. Do you have to use a PC with it or is it stand-alone like a DVR?
God Bless,
-Clint
Clint S. is offline
post #168 of 182 Old 05-09-2014, 08:22 AM
snovvman's Avatar
Well, I ended up with (two) MTV7000D-MINI. On first look, it seems to do what it claims. Now I should be able to offload my live concert recordings from the PVR so I can get it replaced... Interesting box--lots of features.
My AV receiver has two HDMI outputs--one main and one sub. I have the MINI connected to the sub. My theory is that it can then capture any source coming into the receiver (Chromecast, Xbox, etc.). I have the output of the MINI connected to one of the TV's spare input. I noticed that the picture coming out of the MINI is cooler than one directly from the PVR. I wonder if there is a setting for that....
snovvman is offline
post #169 of 182 Old 05-09-2014, 10:03 PM
esdwa's Avatar
@snovvman
Just make sure your sub hdmi always outputs 1080i, not 1080p which is not uncommon these days.
On contrary my setup contains jtech hdmi 2x4 matrix. This way any of my sources which I use for recording can be directed to MINI and at the same time to the receiver bypassing MINI when needed.
esdwa is offline
post #170 of 182 Old 06-25-2014, 09:17 AM
larryccf's Avatar
Quoted: 108 Post(s)
That PLAY sign sounds like a bit of a distraction.
fwiw worth - not sure if you're aware all the carriers (DHL, UPS, Fedex etc) offer pickup svc. UPS will now let you set up an account with online and free. Once you've established the acct, if the vendor will pkg the item and supply you with the weight & dimensions, you can either order a pickup by UPS or print a UPS shipping label that you email to the vendor to use on the pkg. Surprisingly, the pickup svc added quite a bit to a shipment from a supplier in germany, but the label printing route didn't - cost was the same as if i'd shipped the package to them from our location (i have an online business & a UPS account).
i noticed one poster mentioned the vendors would not ship to the UPS, but printing the label and emailing it to them for use, makes you the shipper, and takes it out from under their responsibility. It's should be worth a try asking the vendor
again, fwiw
larryccf is offline
post #171 of 182 Old 06-26-2014, 09:28 AM
larryccf's Avatar
Quoted: 108 Post(s)
just checked magicTV's website and they've got four new models out, the highest end is the MTV8000D http://www.magictv.com/hk/en/mtv8000d.html
and pricing is up to $4280 HK$ or approx $552 USD
larryccf is offline
post #172 of 182 Old 06-27-2014, 08:35 AM
snovvman's Avatar
Originally Posted by esdwa View Post
@snovvman
I'll take a look at that. Thank you.
Edit: BTW, since I have an extra one that I don't need, what is the best way/place to sell that? CL? Do people even know what it is? I'm in the U.S.
snovvman is offline
post #173 of 182 Old 07-15-2015, 02:45 PM
MCaugusto's Avatar
Quoted: 320 Post(s)
Liked: 201
Have you sold the extra MTV7000 Mini you mentioned or do you still have it available for sale ?
Tx....
MCaugusto is offline
post #174 of 182 Old 07-15-2015, 05:09 PM
snovvman's Avatar
Tx....
I still have it--it's been sitting in the box...
snovvman is offline
post #175 of 182 Old 07-15-2015, 05:13 PM
snovvman's Avatar
Apparently I can't PM until I have 15 posts. @MCaugusto : I had a friend buy them in HK and he brought them over when he came to visit.
snovvman is offline
post #176 of 182 Old 07-15-2015, 06:52 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
MCaugusto should be able to PM you his phone number or email and you should be able to read it, you just can't send until you have a minimum number of posts.
Not trying to talk you out of MCaugusto's but Amazon seems to sell a HDMI recorder now, don't know much about it though.
http://www.amazon.com/JIAFENG-100-Di...=hdmi+recorder
jjeff is offline
post #177 of 182 Old 07-15-2015, 07:24 PM
snovvman's Avatar
Yeah--I was replying to MCaugusto's PM above, I just couldn't reply to his PM.
Thanks for the link above, it seems like there is a newer version here:
http://www.amazon.com/JIAFENG-108-bl...p_ob_title_wld
snovvman is offline
post #178 of 182 Old 07-16-2015, 09:28 AM
MCaugusto's Avatar
Quoted: 320 Post(s)
Liked: 201
Thanks snovvman and jjef for all the concern shown as well as the provided link to similar item at Amazon.
snovvman, i just sent you a PM.
Marcos
post #179 of 182 Old 02-23-2016, 06:45 AM
esdwa's Avatar
Marcos
MCaugusto, I just sent you PM. MTV7000 works just fine as on day 1. You can think about it as modern high definition video recorder. Except you can't pull the recording from it as you would take old vcr cassette out. But yuo can watch recording anytime. Paid itself already by saving on monthly DVR subscription from one of cable providers I use.
esdwa is offline
post #180 of 182 Old 02-23-2016, 07:49 AM
Kelson's Avatar
Liked: 1147
Please provide a link to a retailer in the US that you can buy one from.
Or is it still an irrelevant piece of hardware that you need an aunt in HongKong to buy one for you and ship it to The States.
billmich likes this.
- kelson h
Kelson is offline
Tivo
