Philips DVDR3506-getting to Setup w/universal remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-17-2011, 10:43 AM - Thread Starter
joebeagle's Avatar
I have a Philips DVDR 3506 and I am using a Philips universal remote. Problem is I don't know how to get into setup using a universal remote. Without that I cannot set up the clock or set the timer, ect. Anyone have any ideas?
Carol
joebeagle is offline
post #2 of 7 Old 11-17-2011, 01:18 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
You need the original remote or a different universal remote to get those functions. Any harmony like the $20 model 200 will work, as will many one-for-all and cable tv remotes. The codes below work with many cable and one-for-all remotes like the $15 RCA RCRP05B available at many major electronics, department and drug stores using DVD code 1506 or 21506. The manual programming instructions for Advanced codes on the Wiki page linked in my signature tells you how to use the codes.
Spoiler
power 00050
0 00018
1 00010
2 00034
3 00026
4 00242
5 00234
6 00002
7 00250
8 00082
9 00074
channel up 00194
channel down 00186
exit 00022
menu 00001
up arrow 00208
down arrow 00200
left arrow 00224
right arrow 00216
select 00221
play 00051
pause 00147
rewind 00075
fast fwd 00083
stop 00139
record 00123
clear 00008
skip+ 00019
skip- 00011
angle 00230
audio 00064
bookmark 00052
guide 00044
inputnext 00061
random 00076
record mode 00110
repeat 00170
repeat A-B 00219
scan 00099
menu setup 00030
slow 00035
subtitle 00088
system 00058
timer 00189
zoom 00117
eject 00232
hdmi 00095
info/display 00058
ok/select 00176
disc menu 00132
mdavej is offline
post #3 of 7 Old 11-18-2011, 07:31 PM - Thread Starter
joebeagle's Avatar
I can't thank you enough. I went to Radio Shack and bought the Harmony 200. It works perfectly, really slick. The online programming really allowed me to individualize each button. Thank you for your help!
post #4 of 7 Old 07-07-2013, 07:49 PM
Javier Richards's Avatar
hi, i have the same question i have a GE & a rca universal remotes i cant seem to get either one working i see those codes in the spoilers but exactly how do i use them? i really need this to work, is there any way possible to do this? all i can manage to do is turn the thing on and off.... thats it
Javier Richards is offline
post #5 of 7 Old 07-07-2013, 07:53 PM
hi i have the same problem. i cant seem to get any remote to work ive used a GE, Onn, and RCA universal remotes, none of which have completely worked all they managed to do is turn the thing on and off. i see those codes in the spoilers but exactly how do i use them? if you can please reply. i really need this stupid thing to work.
post #6 of 7 Old 07-08-2013, 06:51 PM
mdavej's Avatar
Liked: 940
I assume you already have DVD set to code 1506 since power works. If not, press DVD, hold Setup for 2 blinks, then press 1506 (2 blinks for success).
Then you can start assigning codes per the instructions HERE. For example, to assign the play function to the play button, press DVD, hold Setup for 2 blinks, press 994, tap Setup, then 00051 then the PLAY button (2 blinks for success). Repeat the procedure for all the other functions you need.
mdavej is offline
post #7 of 7 Old 07-08-2013, 07:53 PM
thank you so very much! you have no idea how grateful i am! you just saved me literally 300 dollars! it worked right on the get go.
