LG RC689D... When playing back DVD-Rs on other players no audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-28-2011, 03:53 AM - Thread Starter
snizzler's Avatar
I have an LG RC689D and have worked out the whole 'finalizing' deal in order to play back things I record onto DVD-Rs on other players, but when I do play them back, two small issues.
1. They appear to play back using only half the screen (on the laptop and other player)
2. No audio on the playback on other devices?
not so worried about the half screen thing, not the end of the world, but a bit concerned about the lack of audio on playback. Any ideas?
snizzler is offline
post #2 of 2 Old 12-28-2011, 12:29 PM
profhat's Avatar
Maybe the laptop lacks some specific audio codec, which I found very estrange.
Since your DVD are finalized you could try to extract it's content with "DVD Decrypter" and then check it's integrity with SUPER © - Media File Converter or other tool.
profhat is offline
