Best method for removing Macrovision and CGMS-A? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 01-26-2012, 06:21 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Originally Posted by Church AV Guy View Post
You are quite correct in at least one respect. The Video Filter runs for very long periods of time without heating up, unlike the Sima which can get uncomfortably warm fairly quickly.
Are they still making Simas? I have a few left but I'm mostly using Grex and they don't get hot at all.
joed32 is offline
post #32 of 34 Old 01-26-2012, 12:19 PM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
As far as I know, NO they are not making Simas any longer. I mentioned it because it is the only other device I have to compare with my Video Filter.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #33 of 34 Old 01-26-2012, 04:42 PM
Logic Design's Avatar
Have not had a single incident of a broken connector or any functionality affected by dust when using the video filter. Even if it had a panel, that would not make it stronger since the connectors are attached to the PC board. The PC board has solder mask on it which insulates the pads contacts from dust. There are no thermal issues either. It runs very cool even when it is left powered on all the time which it was designed to.
Logic Design is offline
post #34 of 34 Old 07-05-2012, 08:54 AM
wa4892's Avatar
Is there an updated URL for the Logic Design video filter? The url I had http://home.roadrunner.com/~filter/ does not seem to be working.
wa4892 is offline
