DVD+RW record w/ 1 recorder reformat w/ another recorder? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-12-2012, 02:40 PM - Thread Starter
stevethebrain's Avatar
Quoted: 104 Post(s)
Liked: 25
can a DVD+RW that was recorded w/ one recorder be reformated w/ another recorder (differnt name brand recorder)?
then use this DVD+RW again to record w/ the reformated recorder?
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 13 Old 01-12-2012, 03:08 PM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
Thanks STB
Some will, some won't. My Pioneer recorder won't format any discs that were used in my Panasonic or Magnavox recorders. The Magnavox and Panasonic recorders can re-use discs that were previously used in any of my recorders.
Ken.F is offline
post #3 of 13 Old 01-12-2012, 03:15 PM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
first recorder was panasonic second is Magnavox I believe I attemped this once before can't remember the outcome believe it was unsucsesfull and I just trashed the DVD.
if the reformat w/ 2nd recorder fails is deleteing recordings a option so I can continue to reuse my DVD+RWs ? or will I be forced to use the 1st Panasonic recorder to continue to reuse these DVD+RWs?
Thanks STB
post #4 of 13 Old 01-12-2012, 03:22 PM
Ken.F's Avatar
Liked: 1255
If you used the disc in the Panasonic, the Magnavox should be able to format it. Try using "Erase Disc" from the Magnavox recorder's Disc Edit menu.
Ken.F is offline
post #5 of 13 Old 01-12-2012, 06:53 PM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
OK I'll attemp the erase function of the Magnavox however won't the erase function still leave data on the disc compared to a reformate?
I would prefer to not use the Panasonic to reuse these disc.s (even though it's a better PQ recorder) however I'm thinking I maybe forced to use Panasonic to rerecord on these disc's.
Should I attempt a Magnavox reformate first before I attempt a Magnavox erase?
Thanks Ken.F from STB
post #6 of 13 Old 01-12-2012, 08:30 PM
Ken.F's Avatar
Liked: 1255
"Erase Disc" will format it.
Ken.F is offline
post #7 of 13 Old 01-13-2012, 12:14 AM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 31
I'll defer to Kelson (DVDR / PC Wizard) for the final opinion, but if I were having problems with different DVDRs accepting Erased / Re-Formatted DVD±RWs, I would try re-formatting them on a PC.
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #8 of 13 Old 01-13-2012, 08:58 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1146
This has come up before with RW disks not being able to be reused in different machines. I remember that I recommended to someone in one of these threads to do a full PC erase of the +RW disk with ImgBurn. They reported that they did and it was still unsuccessful getting the other DVD recorder to use it.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #9 of 13 Old 01-13-2012, 09:58 AM
Ken.F's Avatar
Liked: 1255
That was me with my Pioneer DVR-RT500 (A.K.A. Sansui VRDVD-4005). It won't format or write to -RW discs that were previously used in my Panasonic or Magnavox recorders, or formatted by Windows 7 or ImgBurn. I have to keep a set of -RW discs separate for use only in that recorder.
Ken.F is offline
post #10 of 13 Old 01-13-2012, 11:17 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
it worked on the Memerorex disc, I just successfully edited then erased w/ Magnavox then tested w/ a 1 minute record w/ the magnavox.
thanks Ken
STB
yes I to attemped image burn on my PC and was unable to use that disc. on my PC.
STB
the recordings I created w/ the Panasonic where in extended plat (low PQ) got away w/ low PQ w/ my old CRT TV not so good w/ new Hi def.tv so I'll record excellent stuff in SP mode w/ the Magnavox.
Now I'm curious if I can reuse this same erased disc. in my PC. will post up the results.
Thanks Guys STB
post #11 of 13 Old 01-13-2012, 01:26 PM
RichardT's Avatar
Location: Clarkston, Washington (State), Southeast corner
Perhaps only tangentially related, but maybe sometimes seemingly unrelated activity could shed insight on a problem. We are using a Leightronix Controller to control several different devices at programmed times. It signals a couple of Panasonic S29 players to PLAY at their programmed times, and a selected one of six titles on a Pioneer V7400. When the Pioneer was not able to read a -RW (used many times before) created on a Panasonic EH55, I decided to try a +RW, thinking that the +RW might be closer to the Pioneer's preferred format.
When the time came to play title #2 or title #5, which for years have played properly from the -RW, the Pioneer played title #1 from the +RW. These titles are the 90-second "Top of the Hour" station identification and announcements. Must be something different in the way the +RW is built.
RichardT is offline
post #12 of 13 Old 01-15-2012, 11:47 PM
crabboy's Avatar
Quoted: 72 Post(s)
Liked: 61
Correct me if I'm wrong, but one factor could be mode. Pannys (and some others) use Video mode and many others use VR mode. I've found the best way is quoted above: keep separate sets of RWs for each recorder. They can found (I use Sony) cheaply enough.
Indirectly Outta Compton
crabboy is offline
post #13 of 13 Old 01-16-2012, 06:57 AM
Ken.F's Avatar
Liked: 1255
That model Pioneer uses both VR and Video mode.
Ken.F is offline
