Options for Recording After DVDR's Are Gone - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #181 of 207 Old 06-21-2015, 10:05 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Originally Posted by scott967 View Post
I like my Magnavox DVDR, just wish there was a way to pull off titles direct without having to burn DVDs. For a lot of my TV viewing LP data rate / half SD frame is sufficient. I couldn't see trying to store 7 channels 24/7 of HD data.
scott s.
When I save a show I generally have an SD version available I could use but choose not to. I don't worry about running out of space because hard drives are cheaper than blank optical disks. Because my HDHR Prime has a cable card I'm not limited to only the channel tuned on my cable box. I might feel differently if I could get even the main channels OTA but Cable Card and WMC is what I use.
mdavej likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #182 of 207 Old 06-29-2015, 06:35 PM
gastrof's Avatar
Quoted: 118 Post(s)
Buying a spindle of TY/JVC -R discs is about 30 cents each...
How is that less expensive than a hard drive?
As a side question, since I am interested in learning more about computers used as DVRs, is there any way to record something on a computer DVR when the cable system has the channel/program stamped as "do not record" or "one copy only" and so forth?
With the HDMI-to-composite/s-video converters I use with my Magnavox recorders, such "stamps" are filtered out, so I can record whatever I like and even burn to DVD.
Anything along those lines doable with a computer DVR that's using a cable card (or just a QAM tuner)?
gastrof is offline
post #183 of 207 Old 06-29-2015, 08:03 PM
BIGA$$TV's Avatar
Quoted: 63 Post(s)
Liked: 53
My math might be wrong, but I think a hard drive is a bit cheaper per gig than a disc. Assuming $115 for a 3tb HDD and 30 cents for a 5 gig disc.
I won't even get into ease of access with an HDD versus a disc. This is why a lot of people are eschewing discs and going to HDD/servers to store content. I can watch any of 500 or so movies I have without getting up from the recliner.
BIGA$$TV is offline
post #184 of 207 Old 06-30-2015, 08:30 AM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
A computer DVR works the same as a Tivo or Cable/Sat DVR. It respects the copy protection. "Copy Once" can be recorded, "Copy Never" can't. You'd usually only see the latter on a high priced PPV event like a $100 boxing match or something like that. Premium channels are usually "Copy Once", hence recordable. Can you then copy that recording to a DVD? No, because you only get one copy. If it's marked "Copy Freely", then you can. Clear QAM has no copy protection, so you can make as many copies as you want.
Sounds like you have requirements that most of us don't have. I generally record, watch, delete. I never buy PPV, and I almost never archive to DVD anymore. Anything I want to keep, I simply don't delete. I have thousands of recordings on my hard drives at my finger tips with cover art, synopses, etc. No sorting through stacks and stacks of DVDs to find something. And 99% of my recordings are HD.
If you have a lot of protected content and are satisfied with SD DVDs and single tuners, you should probably stick with what you have.
mdavej is online now
post #185 of 207 Old 06-30-2015, 09:02 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Copy protection and scrambling are two different things.
olyteddy is offline
post #186 of 207 Old 06-30-2015, 09:52 AM
mdavej's Avatar
Liked: 940
I never said otherwise. What's your point? If you can explain it more clearly, knock yourself out.
post #187 of 207 Old 06-30-2015, 08:33 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
You did say: "Clear QAM has no copy protection, so you can make as many copies as you want."
There is nothing about Clear QAM that automatically marks it as copy freely. On the other hand Clear QAM is not scrambled so doesn't require a CableCard to decode it.
olyteddy is offline
post #188 of 207 Old 12-17-2015, 09:25 PM
PANASONICPZ85U's Avatar
back to the original poster.
What kind of splitter are you talking about to take an hdmi out and send it to the magnavox
on this cable card i am confused at what they mean at all
http://buckeyecablesystem.net/sites/...leCardInfo.pdf
PANASONICPZ85U is offline
post #189 of 207 Old 12-18-2015, 06:56 AM
gastrof's Avatar
Quoted: 118 Post(s)
I assume you're talking to me?
I spoke of a "CONVERTER", not just a splitter.
The converter takes the HDMI feed and changes it to an S-video or Composite output, with oldstyle white and red left and right RCA jack audio. Thing is, the output can be recorded, no matter how the program was originally coded. (The "how many times copying is allowed" aspect is lost in the conversion S-video/composite.)
I use an HDMI splitter so a "pure" HDMI picture can be fed to the TV, and the other line is converted for use with the Magnavox recorder.
As for "cable cards", I've said nothing about them, don't have a device that uses one (except maybe my FiOS provided cable boxes?), and can't tell you a lot about them.
None of these Magnavox recorders use cable cards.
gastrof is offline
post #190 of 207 Old 12-18-2015, 10:33 AM
mdavej's Avatar
Liked: 940
Cable card is an alternative to DVD recorders. As the previous poster said, there are no DVD recorders that work with cable card.
What cable card gives you for about $3/month is the ability to use your own cable card compatible DVR to record ALL your subscribed channels (including premiums like HBO) in full HD with 5.1 sound. You no longer have to deal with cable boxes, signal converters, low resolution, blocked channels, etc.
As more and more companies switch to all digital, it's an excellent alternative to DVD recorders and expensive cable company DVRs. Furthermore, most have several tuners and multi-room capability and full guide. So you can record/watch several things simultaneously in one or more rooms by simply picking something in the guide (no VCR style timers to deal with), not to mention the much larger recording capacity.
If you want to keep using your DVD recorder, you can. Just plug it into whatever cable card device you used to do your recordings.
post #191 of 207 Old 12-18-2015, 07:36 PM
O wait I forgot that I can start using an antenna to record to the Magnavox with a simple coax wire I might install a rooftop antenna this changes my question completely sorry HD will come in greatly OTA
post #192 of 207 Old 12-18-2015, 07:44 PM
We cut the cable wire back in September but are paying for rabbit ear cable which is stupid I just have not got around to finding one antenna to run all the televisions that is the next project
post #193 of 207 Old 12-18-2015, 07:45 PM
We also use slingbox for walking dead det tigers etc espn
post #194 of 207 Old 12-18-2015, 08:10 PM
mdavej's Avatar
Liked: 940
You mean Sling TV? You can't get those OTA.
post #195 of 207 Old 01-12-2016, 08:03 AM
greene709's Avatar
DVR General Info
Hey folks. I have been away from the DVR scene for a while now and have been having a a bit of trouble trying to find a DVR as they used to exist. Are there still options available to record from a sat/cab box?? I have SD Bell and have an old LG DVR that I still use but would like to upgrade. I am looking for something with a HDD for sure. DVDR is optional at this point. Any suggestions are welcome and thanks in advance.
greene709 is offline
post #196 of 207 Old 01-12-2016, 08:15 AM
mdavej's Avatar
Liked: 940
Yes, but that's a really clunky and expensive way to do it in the 21st century. If you have cable, just get rid of the cable box entirely and use a cable card tuner/DVR.
post #197 of 207 Old 01-12-2016, 08:18 AM
greene709's Avatar
OK. Can I get a box that will unscramble Bell? Or do I have to get one of their boxes?
Thanks again.
Sent from my STV100-3 using Tapatalk
post #198 of 207 Old 01-12-2016, 08:32 AM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
Thanks again.
What is SD Bell? Is it cable or satellite?
Ken.F is offline
post #199 of 207 Old 01-12-2016, 08:33 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
Thanks again.
That's what the cablecard is for. It 'unscrambles' their signal for the device that has the cablecard slot.
I bit the bullet and bought a TiVo Roamio this fall when they had the fire sales before the Bolt came out. The TiVo hardware is kinda expensive, and then you have to factor in their subscription fees, or buy it outright.
My cable company (Mediacom) charges $2 per month for the card and I can use my own HD DVR. And use it anywhere in the house.
NickTheGreat is offline
post #200 of 207 Old 01-12-2016, 08:35 AM
greene709's Avatar
it's Satellite. bell express u.
post #201 of 207 Old 01-12-2016, 08:37 AM
Ken.F's Avatar
Liked: 1255
CableCARD won't work with satellite.
Ken.F is offline
post #202 of 207 Old 01-12-2016, 10:25 AM
Quoted: 381 Post(s)
Liked: 255
Yeah that's a whole different animal
post #203 of 207 Old 01-12-2016, 03:21 PM
greene709's Avatar
So can anyone suggest a good stand alone set top dvr?
post #204 of 207 Old 01-12-2016, 03:34 PM
mrmazda's Avatar
Quoted: 113 Post(s)
Liked: 41
Other thread explains what Funai offers and has offered if you read it all and some of its links, esp. the one to the thread that spawned it.
Genuine HD via ATSC and BUD satellite DVB.
Team OS/2 ** Reg. Linux User #211409
mrmazda is offline
post #205 of 207 Old 01-13-2016, 04:29 AM
greene709's Avatar
Sent from my BlackBerry Priv
post #206 of 207 Old 01-15-2016, 09:10 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
wajo is offline
post #207 of 207 Old 02-19-2016, 02:50 PM
legacykeeper's Avatar
I know from experience, clearQAM can be copy protected, and the Magnavox DVRs comply. Most frequent is the "copy once only" flag, which means no DVD can be made --- even from a legal short excerpt of the flagged title. And, recording can be prohibited entirely, though that has been very uncommon in clearQAM.
legacykeeper is offline
