Is it possible to completely remove the menu? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-29-2012, 08:50 AM - Thread Starter
Argalby's Avatar
I have a Magnavox 2160A. When I dub DTD is it possible to completely eliminate the menu so the DVD just starts playing the movie when inserted in a player? Thanks!
Argalby is offline
post #2 of 7 Old 01-29-2012, 09:00 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
No option for that. The best you can do is use a +R disc, insert on tray but don't close tray, press PLAY on remote. That'll draw tray in and start playing "immediately." (with no menu).
wajo is offline
post #3 of 7 Old 01-29-2012, 09:18 AM - Thread Starter
Argalby's Avatar
Thanks Wajo! I'd sort of suspected that but just wanted to check with the experts
I had a Samsung DVD R-130 that would record without a menu, but that unit's dead now, and probably just as well....it was very finicky about what it recorded, and lots of times it wouldn't finalize.
Really happy with the Magnavox 2160A....just updated to; first 727H, and then Super 727V firmware...all seems well so far I really appreciate all the help on this forum! Thanks!
Argalby is offline
post #4 of 7 Old 01-29-2012, 10:13 AM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Thank you for posting on how you did your FW update... progressively, whcih I think is a good (safe) idea. Only downside is exposing the machine to two chances to mess things up!
wajo is offline
post #5 of 7 Old 01-29-2012, 10:49 AM
profhat's Avatar
I know your pain.
profhat is offline
post #6 of 7 Old 01-29-2012, 12:07 PM - Thread Starter
Argalby's Avatar
Originally Posted by profhat View Post
I know your pain.
Yes! And I called Samsung....parts are no longer available.
Argalby is offline
post #7 of 7 Old 01-29-2012, 12:10 PM - Thread Starter
Argalby's Avatar
Glad to help out. Yes changing FW is a scary procedure. However that new 727V Super FW is great! Now I can title my timer recordings ahead of time...very slick!
Argalby is offline
