Cannot Get Setup Screen for Panasonic DMR-E100H on TV LG 42LV450U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-04-2012, 09:17 AM - Thread Starter
victormatfield's Avatar
Hi
I recently bought a second hand Panasonic DMR-E100H. I followed the instructions and set it up as follows.
DMR-E100H (TV Socket) SCART to LG TV (AV2 IN) S-Video
DMR-E100H (Satellite) SCART to Sky Satellite Decoder (VCR) SCART
ANTENNA Co-axial to DMR-E100H AV RF-IN
DMR-E100H RF-OUT Coaxial to TV-Antenna IN
When I change the INPUT on the TV remote to AV2 and turn on the DVD recorder I get no signal. According to the instructions the channel setup menu is supposed to appear.
If I play a movie in the DMR it automatically switches and plays
If I put a blank DVD+R disc in it says no disc.
Any help would be appreciated as I'm at the pulling my hair out stage
victormatfield is offline
post #2 of 3 Old 02-04-2012, 10:15 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
I don't know about your SCART questions since we don't use that connection here but the E100H doesn't support the + format, only - and RAM.
jjeff is offline
post #3 of 3 Old 02-06-2012, 03:23 PM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
I don't have a manual for the E100H, but I can tall you that my Panasonic international models have SCART connections, and they are tricky to use at best. Does the E100H have connections other than SCART that you could use, to test it?
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
