Need help with my Panasonic DMR-EH69 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-27-2012, 08:45 AM - Thread Starter
zmann96's Avatar
Hi Guys, I purchased a Panasonic DMR-EH69 about a year ago, I really like the unit for my use. The other day my kids got a hold of the remote and got into settings. I've been trying to reset the unit but my TV screen is rolling and can't see the menu to reset. I read the manual and tried the auto reset but that didn't work. I tried putting in a DVD and the screen stopped rolling for that but I can access anything from there to reset. Can anyone help? Thanks in advance.
zmann96 is offline
post #2 of 5 Old 02-27-2012, 12:35 PM
Church AV Guy's Avatar
Quoted: 118 Post(s)
Liked: 89
Look at the users manual, page 60, bottom of the page. It says:
To change the setting all at once (PAL!#NTSC)
While stopped, keep pressing [STOP] and [ OPEN/CLOSE] on the
main unit at the same time for 5 or more seconds.
Since the problem went away when you put in an NTSC DVD and played it, I would guess that they might have done a master reset which will (I think) put the machine back into PAL mode. When you played an NTSC DVD, it will putput NTSC signals, even if the mode selected is PAL, so that is a clue.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #3 of 5 Old 02-27-2012, 01:10 PM - Thread Starter
zmann96's Avatar
Thanks Luke, I'll try that.
zmann96 is offline
post #4 of 5 Old 02-27-2012, 02:24 PM - Thread Starter
zmann96's Avatar
I tried that from page 60, still nothing. If I could just get the screen to stop rolling so I could use the remote to set it up it would be fine but the screen is rolling so fast I can't see the change the settings. ?????
zmann96 is offline
post #5 of 5 Old 02-27-2012, 02:49 PM - Thread Starter
zmann96's Avatar
Just got it, put it on AV4 and tried the set and it worked. Thanks again Luke
zmann96 is offline
