Blank DVD recomendations - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #61 of 68 Old 05-15-2017, 12:45 PM
mallo's Avatar
Quoted: 17 Post(s)
Regarding Verbatim AZOs, I seemed to have more failures with the -R DVDs than with +R. I read somewhere that +R was better (at least on the Magnavox DVRs -- something to do with initializing the DVD for burning, IIRC.
So I switched to +R, and I do seem to have fewer burn failures, but I can't buy them locally. I can get the -R locally, so I'm trying to decide whether to try them again, or just stick to the +R and order them online.
Thanks for any advice.
mallo is offline
post #62 of 68 Old 05-15-2017, 02:38 PM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
With a Magnavox and especially considering you've had good luck with them, I'd really suggest sticking to the +R type. Now if you had a Panasonic or Pioneer I'd say -R but with Funai based machines + seems to be the favored format.
Note Amazon is probably the best place to get AZO Verbatims and generally the + format is easier to find cheaper, they haven't had any great deals on -R Verbatims in quite some time In fact as I was basically out, so for my most recent purchase I ended up getting them B&M from Microcenter who had just one -R AZO 100 spindle for $21.99, they had tons of +Rs and I also got one spindle of the cheaper Life -Rs for $15.99 which burn perfectly well in my PC.
jjeff is offline
post #63 of 68 Old 05-15-2017, 04:04 PM
mallo's Avatar
Quoted: 17 Post(s)
Thanks! I'll stick to the +R.
I usually get them from Amazon now, but I used to get them at my local Microcenter, which even had them on sale once in a while. Now they only have -R, and only a couple of spindles of those.
From reading through this topic, I gather that there aren't any better quality DVDs available anymore? IIRC, I still have some MIJ Sony DVDs that I hoarded several years ago. Do these things go bad?
mallo is offline
post #64 of 68 Old 05-15-2017, 05:41 PM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Funny, my local MC had rows of +R AZO Verbatims but only the one -R 100 spindle which I got. When I asked if they had more they looked it up and said the computer showed that had 0.....
I've never heard anything about blank DVDs going bad, I suppose if they were stored in the sun, individually it might not be good for them, but I've burned 10 year old DVDs with no issues.
jjeff is offline
post #65 of 68 Old 05-16-2017, 06:07 AM
greaser's Avatar
Quoted: 111 Post(s)
Liked: 66
I had about 15 blank Sony +RW discs left over from a 25pk i bought in 2006 go bad.They were stored on a shelf,in a cool spot,away from the sun.
I only used about 10 of them after i bought them,the rest i didn't use for years after i switched to T-Y -r discs.
Last year i finally decided to use them up,but no luck,none of my recorders would accept them.
Of the ten i did use,ALL still play well today.They are the longest lived discs i own...11 years now.
greaser is offline
post #66 of 68 Old 05-16-2017, 07:28 AM
mickinct's Avatar
Quoted: 214 Post(s)
Liked: 904
Last week I was looking for a title 1971 Vantage Point and found it in my library, recorded on a COMPUSA dvd-r on my first Panasonic dmr-e20 in 2002, and it played perfect, do not the vendor who made them for compusa.
MickinCT
mickinct is offline
post #67 of 68 Old 05-16-2017, 10:43 AM
Kelson's Avatar
Quoted: 2030 Post(s)
Liked: 1209
I would be willing to bet that if you attempted to burn those 15 +RW disks in a modern PC burner, they would burn just fine. The burners they used in DVD recorders were never on the high end of the quality scale.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #68 of 68 Old 05-16-2017, 10:21 PM
mallo's Avatar
Quoted: 17 Post(s)
I've found MC's computer inventory system to be flawed. It often doesn't match what's actually in the store. I was at the local MC today, and they did have ONE spindle of +R AZOs, but it was the imprintable kind, so they were more expensive. Not worth it to me, since I never imprint.
I'll just keep an eye out for a sale at Amazon.
BTW, the blank media section at MC has really shrunk. Used to be one side of an entire aisle. Now it's about half that.
mallo is offline
