DVD format - AVS Forum | Home Theater Discussions And Reviews
Old 03-20-2012, 06:34 PM - Thread Starter
1jimbir2's Avatar
I have a magnavox ZC320MW8B/F7 DVD recorder. after I erase a disk on it then look at the properties of that disk on the drive in my computer I see a result as shown in the attached picture. I'd like an explanation of why it shows 3.46 GB of used space on a supposedly empty disk. there are TS and RM folders on the disk with some files in them but these only add up to a little over 1 MB.
Just curious, Jim B.
I'd like to add another question. If I set the recording mode to SP (2 hrs) what happens if what I am recording runs a little over 2 hrs (say 10 minutes)?
1jimbir2 is offline
Old 03-20-2012, 07:51 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
The DVDR OS doesn't "delete" files just the pointers (location info) to the files, so it sees a "blank" disc... all space available for re-recording over the "deleted" files. The PC OS doesn't understand DVDR file systems so it just sees the files still on the disc.
If you do a manual recording (press REC), you should be able to get over 2 hours... the HDD Mags can get slightly more than 2:10:00 at SP. Let a recording run to end of disc just so you know how many minutes your unit can record manually (real-time record, or RTR).
Here's a chart of DVD rec times for the HDD Mags.
wajo is offline
