Sony DVD Recorder RDR GX-300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-22-2012, 03:32 PM - Thread Starter
PMB707's Avatar
I have a Sony DVD Recorder RDR GX 300 that will not read DVD's and I have numerous unfinalized DVD's since I record certain horse races and keep adding to each DVD. Sony Repair Center in Texas says they no longer make parts to repair this unit which is only about 7 years old. I think that is disgusting. Any ideas on how to finalize these DVD's or find a replacement unit would be appreciated.
PMB707 is offline
post #2 of 6 Old 03-22-2012, 03:50 PM
gastrof's Avatar
Quoted: 118 Post(s)
Check my reply to your post in the other thread.
As for double posting, that's a no-no.
You should post your request for help either here or there, not in both places. Just a bit of friendly advice.
gastrof is offline
post #3 of 6 Old 03-25-2012, 08:39 AM
tomwil's Avatar
Liked: 26
Perhaps the OP forgot where he posted before:
http://www.avsforum.com/avs-vb/showthread.php?t=981951
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #4 of 6 Old 03-25-2012, 03:32 PM
profhat's Avatar
My advice: you will need to buy a working second hand RDR GX 300 or a model compatible with your DVDs from ebay or Craiglist, then just finalize your DVDs
After that, you will need to buy or assemble a good HTPC, since the DVD recorders are now dead. Or go TiVo.
profhat is offline
post #5 of 6 Old 03-25-2012, 03:39 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
DVD recorders are not dead, just taking a nap!
wajo is offline
post #6 of 6 Old 03-25-2012, 04:00 PM
profhat's Avatar
They will raise again on April 1st.
Anyway you're right, there's still hope for a HD BR-recorder for the US...
profhat is offline
