record digital cable channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-09-2012, 06:18 PM - Thread Starter
stoutd's Avatar
My cable company doesn't offer a cable card or cable box. They just require a digital TV with a QAM tuner. I know TiVo won't work. I need to be able to record channel 5-1 and 101-2 for example. A DVD recorder would be ok.
stoutd is offline
post #2 of 5 Old 05-09-2012, 07:00 PM
profhat's Avatar
Yes, for example, the Magnavox 513/515 will be fine.
profhat is offline
post #3 of 5 Old 05-09-2012, 09:45 PM
Kelson's Avatar
Quoted: 2030 Post(s)
Liked: 1209
Wow, no card or box? They are sending everything in clear QAM? What an anomaly. A funai DVD recorder will work but only in SD. Do you want to record in HD/5.1?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4 of 5 Old 05-10-2012, 08:41 AM - Thread Starter
stoutd's Avatar
I know it is hard to believe in 2012. They tell me they will do something at the pole to scramble the channels when they start charging for them. They have been upgrading to digital/HD for a few years now. It is small operator in a rural area. Celina Cable/Overton County Cable in Tennessee.
stoutd is offline
post #5 of 5 Old 05-10-2012, 08:48 AM
Guest
Quoted: 38 Post(s)
Liked: 198
7558037 is offline
