What DVD will be produced from NTSC 4.43? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-26-2012, 12:51 AM - Thread Starter
Cyclone82's Avatar
If i have a VHS player that can only play a NTSC 3.58 tape converted to NTSC 4.43 (not keep it at its native 3.58mhz) what format DVD will be made from that signal if fed into a DVD recorder assuming it can accept a NTSC 4.43 signal through an AV input? Will it make a proper NTSC 3.58 standard disc?
Cyclone82 is offline
post #2 of 4 Old 05-27-2012, 01:11 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Keep in mind that NTSC 4.43 is not PAL. The sub carrier frequency is the same as PAL because of the 625/50 frame structure. But PAL is a different encoding standard and while some parts are the same such as the 0/90 degree modulation axis, it is not compatible with NTSC due to it's carrier phase reversal every other line.
Glimmie is offline
post #3 of 4 Old 05-28-2012, 01:16 AM - Thread Starter
Cyclone82's Avatar
So are you saying it would make a PAL DVD and not a NTSC DVD?
post #4 of 4 Old 05-28-2012, 01:30 PM
gastrof's Avatar
Quoted: 118 Post(s)
"Keep in mind that NTSC 4.43 is not PAL. The sub carrier frequency is the same as PAL because of the 625/50 frame structure. But PAL is a different encoding standard and while some parts are the same such as the 0/90 degree modulation axis, it is not compatible with NTSC due to it's carrier phase reversal every other line."
gastrof is offline
