DMR-ES40V - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-23-2012, 02:20 PM - Thread Starter
madra's Avatar
Originally had the F60 error. I get rid of this by turning unit off for a 1 minute and when the series of 00000 start I press the power button. The time 12A appears in the readout. by pressing I think the menu button I get readout 'Hello' this is where is all stops. The VHS eject works but the DVD tray will not come out. Have not used the unit for over a year and am not sure whether or not there is a disc on the DVD tray.
AND should the light on the front of the remote light when I press buttons?
Is there a way to test the remote?
Any help would be greatly appreciated
Thank you,
Charlie
madra is offline
post #2 of 4 Old 06-25-2012, 08:49 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Originally Posted by madra View Post
...the DVD tray will not come out. Have not used the unit for over a year and am not sure whether or not there is a disc on the DVD tray.
Thank you,
Charlie
Welcome to the Forum.
The IR does not "light" when the buttons are pressed.
This addresses the problem with the disc tray:
DMR-ES30 SM PAGE 13.jpg 392k .jpg file
Name:	DMR-ES30 SM PAGE 13.jpg
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #3 of 4 Old 06-26-2012, 01:23 PM
jjeff's Avatar
Quoted: 690 Post(s)
Liked: 246
Thank you,
Charlie
The easiest way to verify the remote is sending out a signal is to point it towards a digital camera and observe the electronic viewfinder, the LED should blink when you push buttons on the remote. You can use a digital camera or even your cell phone if it has a camera.
jjeff is offline
post #4 of 4 Old 07-02-2012, 02:43 PM - Thread Starter
madra's Avatar
Thank you for that we have tested the remote and find that it is functioning ok.
Sorry for being slow to respond. I have been away and now have visitors from Ireland
madra is offline
