Pioneer DVR-540H-S Please help - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2012, 02:25 PM - Thread Starter
greyeyes's Avatar
Hi. I feel really stupid but I'll swallow my embarrassment for any help anyone can give.
I just purchased a used Pioneer DVR-540H-S hdd/dvd recorder from a good ebay vendor after reading that it was a very solid unit. I paid $399 U.S. It came today.
I've hooked it up in the simplest way possible - just like a vcr. Outside cable directly into the VHF-UHF (RF In). another cable from the VHF-UHF (RF Out) to the Cable-In connection on TV.
I turned on the dvd recorder. The front panel display reads "SETUP NAV"
That's it. I can't get any menus for setting up to appear on screen - no matter whether I push Home Menu' or 'Top Menu' or 'Disc Navigator' or 'Help' on the remote control. Nothing is happening on screen to help me get set up.The tv (an old CRT) is set to channel 3 - I've switched it to channels 2 and 4 to see if that would make a difference - it didn't.
Very fustrating.
Can anyone help me with this? Like I said before - this is kind of embarrassing.
greyeyes is offline
Old 06-28-2012, 02:48 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
You'll only see internal stuff (menus, titles, channels, etc.) via a "line connection" to the TV: Composite YWR, S-Video+W/R audio, or Component RGB+W/R audio (if those connections ar available on both TV and DVR). Select the input you connect to on your TV to see internal stuff.
The coax is diff. than a VCR, it's only a "passthru" of the raw incoming signal so your TV can tune channels independently.
wajo is offline
Old 06-28-2012, 04:10 PM - Thread Starter
greyeyes's Avatar
Thanks, wajo.
The last dvd-hdd recorder I purchased was the LG LRH-890 model. I hooked it up very simply - just like a vcr - and everything - all the workings and menus - appeared perfectly. I like to record (archive) movies but am not a videophile in any way. So, the simple co-ax connections have always been good enough for me, high def not something I worry about (just so long as I'm getting the SP quality of a dvd played through a JVC vcr).
So, when no menus would come up after connecting my new used Pio, it threw me. A connector that came with the unit is one of those three imput composite cables - the thick ones with one red, one blue and one green connector. I connected that from the dvd recorder to the tv and set the tv to component 1 and sure enough the menus became visible. However, with that connection I get no sound (??)
After reading your post I went and found myself a set of those RCA connectors (red, white, yellow) and plugged those from the dvd recorder to the inputs on the tv and found that that worked with the tv set at AV3. And this time I'm getting sound, so that's a relief.
So, thanks again. It's not a perfect set up as the connectors are too short to reach from the recorder to the tv and therefore I had to seperate the recorder from my bench with my other components and bring it around by its lonesome to the other side of the tv. It's presently resting atop a old floor speaker that's positioned next to the tv. As long as the speaker doesn't get bumped into in a hard way, I think it'll be okay.
Do they sell extra long red, white and yellow connectors (like about 6 feet long, do you know?). I'd really like to bring the recorder back to the rest of the components.
greyeyes is offline
Old 06-28-2012, 05:18 PM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
Originally Posted by greyeyes View Post
Thanks, wajo.
You will need to connect two audio cables like the red/white parts of the red/white/yellow cable you used below. The component cable red/blue/green carries only the video information. It y would be advantageous for you to use this component connection as it supports analog HD, and will give you a better picture. Just go to a radio shack and get a stereo audio cable of the same length as your component cable. On the other hand, you can look here and get a nice five conductor cable (RGB + audio) in the appropriate length (1.5ft - 100ft).
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10235
Here is a link to the composite cables by the same company (1.5ft-50ft).
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10241
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
Old 06-29-2012, 09:14 PM - Thread Starter
greyeyes's Avatar
Thanks so much, Church AV Guy. You've shown me exactly what's needed and I'll probably get it here in Canada if the price is reasonably close.
greyeyes is offline
Old 06-29-2012, 09:53 PM
CitiBear's Avatar
Quoted: 102 Post(s)
Liked: 91
You should enjoy using your new DVR-540, greyeyes: it is one of the later, nicer Pioneer models (I own two myself, bought when Canada CostCo closed them out a few years ago). The 540 can be a little picky about blank media, I strongly suggest you use only these or these, they should be available from Canadian vendors. Avoid store brands, Maxell and TDK. Sony can be OK but is unpredictable. For - or +RW, stick to Verbatim.
Your LG-890 was unusual in having RF connections that worked like the old VCRs did: very few DVD recorders have that, they all rely on the composite or component connection for viewing on the TV. The MonoPrice cables recommended by ChurchAVGuy are a safe bet, and may be worth paying the extra to have shipped to Canada. I have found the cables sold in local stores lately to be very poor quality. You should be OK with cables bought from Future Shop or other major chains, but they tend to overcharge. Try to keep the length at 6 feet if at all possible: 8 foot and longer cables tend to have the most problems.
CitiBear is offline
Old 06-30-2012, 10:58 AM - Thread Starter
greyeyes's Avatar
Thankyou, CitiBear. I've been reading the posts here at AVS for a while regarding DVD recorders and blank media, but was still concerned about what was available in Canada that would be agreeable to the Pioneer. I'm always wary of importing because of Canada Customs practices and additional expense.
So, your advice comes at the perfect moment. I've ordered 100 of the Taiyo Yuden silver lacquer premium from BlankMedia.ca to get me started.
I can't help but notice from my shopping around online the past couple of days that 8x media is becoming more and more scarce - 16x seems to be what's most common now. But, from reading posts here in these forums, I shouldn't even try using 16x on a dvd recorder. I guess we have to hope that 8x will continue to be available for the foreseeable future.
greyeyes is offline
Old 06-30-2012, 09:25 PM
CitiBear's Avatar
Quoted: 102 Post(s)
Liked: 91
greyeyes, you CAN use some 16x media in a Pioneer 540, but stick to the better brands like Verbatim and TY. In 16x, I would go with the TY +R instead of -R, its a little more reliable in the 540, while with Verbatim the 16x -R usually is a bit more compatible. Short term, buy the 8x -R from a Canadian dealer for as long as its available. I have owned six different 540s, and each started getting cranky with most 16x blanks within a year or so of heavy use. When I swapped to 8x, they worked fine.
The trick with 16x is to find a specific brand and type that the 540 "likes," then stock up on a lot of it. But this requires annoying trial and error, while the 8x is guaranteed to always work reliably. I have no patience with media problems, so I'll be buying 8x until I can't find it anymore. Others here with similar recorders say they can burn any 16x bargain brand reliably, 110% of the time. I envy their good fortune. Sometimes its a simple thing like differences in the lacquer surface: some 16x discs are more "grippy" and easier for the recorder to spin than others.
CitiBear is offline
Old 07-06-2015, 05:02 PM - Thread Starter
greyeyes's Avatar
Well, after 3 years of transferring movies from the hard drive of my LG recorder to the hard drive of this Pio 540 and then burning dvd's with the Pio, a problem has occurred with the 540 today.
The line inputs (red, white, yellow) have stopped working. I know that is the problem because everything else is working fine - and because I disconnected the 540 and connected a 660 in its place and all is good. I was very lucky to have come across a 660 at a very good price just a few months ago, or I'd be out of business completely.
Am I looking at an expensive repair on my 540? Where would I take it?
greyeyes is offline
Old 07-07-2015, 08:23 AM
CitiBear's Avatar
Quoted: 102 Post(s)
Liked: 91
The Pioneer 540 has three sets of line inputs. Is it possible you merely picked up the remote in such a way that you accidentally hit the button that switches inputs? Try pressing the remote "input" button several times to cycle the machine thru Line 1, Line 2, Line 3, Tuner, and back to Line 1 etc.
Have you tried your cables on each of the three input sets? It is very unlikely that all three would go bad simultaneously: the one upfront (Line 2) is physically separate from the back panel Line 1 and Line 3. I suppose it is possible a power surge could have burned out a microprocessor that all three inputs pass thru, but that would be quite unusual. Generally in these cases it is either the wiring/plugs developing a short, or the connectors of a particular input in the recorder developing a solder crack.
The latter frequently occurs when the front inputs are in continual use for dubbing: the weight of the cables pulls on the flimsy board mounting until the internal solder traces crack from stress. For constant dubbing, the rear panel inputs are a better choice in most recorders than the front (the rear connection panel is mounted securely to the metal chassis and doesn't wiggle, the front panel is unsupported internally and just pokes thru plastic holes in the front face).
CitiBear is offline
Old 07-07-2015, 08:19 PM - Thread Starter
greyeyes's Avatar
Thank you so much, CitiBear!
This has been a learning day for me. I did what you suggested - stepped through the input select and it came back online with the L3 input! It had gotten switched to L2 somehow. I have the gray remote that has the bottom section that must be opened to access the input select and other controls, so it never occurred to me that a change could have happened - even accidentally. But it did.
Everything is back to usual now, thank you. But I did learn that I can alternately connect from one dvd recorder to the other through the co-axial, just as long as I set the receiving recorder to channel 4. So, even if I ever do lose the line input for some reason, I'm not necessarily out of business. Like I said - lots learned today.
I probably shouldn't admit this, but without any special filters or stabilizers or descramblers, I am able to copy any commercial dvd to a dvd-r using just my basic equipment. Nothing has been able to prevent it - not Macrovision, not anything. The only condition is that I must accept these recordings in mono sound.
Electronics are very much a mystery to me, but I learn practical methods of operation with every experience (often trial and error related).
Thanks again for your suggestion - it made me realize that nothing is wrong with the 540. Happy day.
greyeyes is offline
