Recommendations: For a Camcorder for my BLU-RAY/DVD Recorders - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-09-2012, 05:36 PM - Thread Starter
HDTVMARTY's Avatar
I have the DMR-BS850 Panasonic High Definition Blu-Ray/Dvd Recorder and the DMR-EH69 Panasonic recorder.
My questions are the following: 1) I am looking for a HIGH Definition Camcorder that will work with my DVD Recorder through the IEEE 1394 firewire port or the USB port.
Allowing me to transfer my home video movies from a HD Camcorder to a Panasonic DVD Recorder or to my DMR-BS850 Blu-ray High Definition recorder, which also has the Firewire IEEE 1394 ports and USB port.
What type of HD Camcorders would you recommend that would be capatible with Panasonic DVD/Hdd Recorders.
Does anybody have any recommendations and experience for buying a HD camcorder that can copy or transfer its recordings onto a DVD Recorder.
Thanks for any Information or advice.
HDTVMARTY is offline
post #2 of 2 Old 09-10-2012, 01:20 AM
profhat's Avatar
Without be an expert, I recommend you to try the Panasonic HDC-SD1. Of course there must be many other options, so let's see what the guys say about this.
profhat is offline
