Power-up problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-20-2012, 09:46 AM - Thread Starter
bobcat6700's Avatar
I have a Magnavox 515H which is two months out of warranty and suddenly neither the remote or front panel button will turn the unit on. It has adequate ventilation. If I unplug the unit for 15+ seconds, I hear two succesive clicks and still will not turn on. Maybe an internal circuit breaker turning on and off?
I have not opened it up but certainly will if someone has a suggestion to repair/remediate. It would likely cost too much to warrant repair if I have to pay for a service fee plus parts. It is apparently not an uncommon problem as Magnavox addresses it in their FAQ. None of their suggestions help.
Does anyone have a fix? Thanks for your response.
Bob
bobcat6700 is offline
post #2 of 6 Old 09-20-2012, 09:59 AM
Quoted: 38 Post(s)
Liked: 198
Bob
A simple Soft Reset will fix it.
Click 1st link in my sig. for a list of more help files like that one.
bobcat6700 likes this.
7558037 is offline
post #3 of 6 Old 09-20-2012, 12:46 PM - Thread Starter
bobcat6700's Avatar
WAJO, you were right. I followed your instructions exactly with positive results. Thank you for your help.
Also, many thanks to Mickinct for his suggestions...I learned much from talking to you.
Bob
post #4 of 6 Old 09-20-2012, 12:57 PM
mickinct's Avatar
Quoted: 207 Post(s)
Liked: 902
YOUR welcome good for you.
MickinCT
mickinct is offline
post #5 of 6 Old 09-27-2012, 01:55 PM
Slippery10's Avatar
Hi my name is Mike Eeles I have owned a dmr e85h for 11yrs and has performed faultlessly
But last night I performed its last recording this morning it failed to power up ,
I have checked power lead ok have opened up unit and checked fuse on power board ok
Have removed power board and cannot see any capacitor damage ie blown or leaked with the thought of repairing my self !! I need to be sure of problem/solution or a good guy who can fit it can you advise I live in Berkshire email mgeeles52@yahoo.co.uk
Slippery10 is offline
post #6 of 6 Old 09-27-2012, 02:26 PM
Church AV Guy's Avatar
Quoted: 117 Post(s)
Liked: 89
Slippery10, I would recommend you send a PM to MICKINCT. He fixes Panasonic DVD recorders, and he does a very good job. This forum has many endorsements of his work.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
Magnavox
