How to dubb from HDD to DVD at a diffrent recording mode. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-03-2012, 08:30 AM - Thread Starter
Waseem's Avatar
Hi All,
I am sure that some of you will be looking at this topic and saying "WHAT...."but what I am trying to do here is to move some recordings that are not very important from the HDD to some DVDs but some of these are recorded at HQ, and I need to conserve on DVDs so I want to dubb them onto DVDs using the EP or even SLP mode to get the most usage of the DVD.
Thanks for any advice.
Waseem
Waseem is offline
post #2 of 2 Old 10-03-2012, 08:38 AM
Quoted: 38 Post(s)
Liked: 197
Here's the help file on dubbing HDD>DVD.
Basically, the dubbing menu will give you an option to select the rec mode of the dub, from HIGH (high-speed lossless dub) to SLP, your choice, depending on what will fit on the DVD.
Please click the 1st link in my sig, for an index of help files where this info is available.
7558037 is offline
