Magnavox 533 Input Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-06-2012, 12:44 PM - Thread Starter
Highnoon1's Avatar
I really like my new Magnavox 533 but I've run into a problem. My STB has composite and component outputs, but only in resolutions of 480P, 720P, and 1080i. My Magnavox will not take any of those resolutions on the composite input. I could get an adapter cable to go from the STB component output to the Magnavox s-video input but I don't know if it can handle that either. Does anyone know anything about this or what I can do about it ? Thanks for any reply.
Highnoon1 is offline
post #2 of 9 Old 10-06-2012, 12:55 PM
Quoted: 38 Post(s)
Liked: 197
It seems there almost has to be a way to set the STB for 480i output over Composite Yellow, or why have Composite... it can't handle any Progressive signal. That's why they developed Component RGB. Some devices do that automatically, no matter what the Progressive setting (like my Pioneer DVR-640)? Maybe you have to turn Progressive off?
However, if you just can't get composite Yellow to work the way you want, there are converters described here that will take a HDMI or Component signal and convert it to Composite Yellow oir S-Video.
Click the 1st link in my sig. for the main thread on these units and lots of info and help files.
7558037 is offline
post #3 of 9 Old 10-06-2012, 02:26 PM
jjeff's Avatar
Quoted: 768 Post(s)
Liked: 268
As Wajo said composite is only and will only be 480i. Now your STB may disable the composite output when set to anything other than 480i or may disable component output when set to 480i(not every device with component output is able to output 480i over component). Something just doesn't sound right......
If your not using the component output one of those cheap component to S-video converters would work but only the more expensive ones have component passthru to also run to your TV.
jjeff is offline
post #4 of 9 Old 10-06-2012, 04:00 PM
CitiBear's Avatar
Quoted: 115 Post(s)
Liked: 97
Double check which input jack is selected in the Magnavox VIDEO>VIDEO INPUT menu. For composite (yellow RCA jack), the menu selection should be "VIDEO IN." That is the default setting on new recorders, but its possible yours might be set to "S-VIDEO" instead. If so, it won't see anything at all thru a composite connection to your STB. Change the setting if it reads "S-VIDEO" (unless you're using the S-Video output of your STB- then you would want the Magnavox to be set at S-Video to match). S-Video is also 480i, just a different, better connector.
Try different composite jacks on your Magnavox, both front and rear- its possible you have a dead jack (unlikely, but possible). Try a different wire (swap one of the audio wires for the video): maybe a bad wire.
Composite is locked at 480i, so no matter what resolution you choose on your STB the composite output will always be 480i (even if the component output is set to 720p). Each STB has different capabilities: the older ones had separate jacks for composite (yellow) and component (green-blue-red), and could usually send 480i thru the yellow jack and 720 or 1080 thru the component jacks at the same time, to feed both a recorder and a TV. Some of the newer boxes allow just one connection at a time: if you have one of those boxes it will have a menu setting somewhere to choose which output you want to use.
I've never seen a STB that does not offer a 480i option along with 480p, 720p, and 1080i. There has to be some way to select that setting, if all else fails contact the service dept of your cable or satellite provider for help. If it turns out there really is no 480i setting in the box, it may be just a limitation of the component outputs, but the composite is 480i for sure so there wouldn't be any other resolution choices for it (it should just work).
CitiBear is offline
post #5 of 9 Old 10-06-2012, 04:38 PM
Quoted: 38 Post(s)
Liked: 197
I think the Video Input sertting is probably it.
Check your Video > Video Input menu and set for "Video In" if using composite or "S-Video in" if using S-Vid.
7558037 is offline
post #6 of 9 Old 10-07-2012, 08:12 AM - Thread Starter
Highnoon1's Avatar
I cannot believe how incredibly stupid I am. You guys were right - it was the video input setting. I had forgotten all about that - it was set for s-video because that was the output of my old STB. Everything works great now. I would still prefer to use the component output from my STB, so I can just buy an inexpensive component-to-s video adapter cable to input to the Magnavox. My STB also has an HDMI output which goes to my tv. You guys are the best - thanks so much for the replies and the advice.
By the way, for your own information, I also did connect that composite output from my STB directly to my Panasonic tv and pressed the INFO on the remote, which indicated that it was indeed a 480P signal. Go figure !!!!!
post #7 of 9 Old 10-08-2012, 03:06 PM - Thread Starter
Highnoon1's Avatar
It looks like I spoke too soon. Evidently, you cannot convert from Component to S-Video with a passive cable adapter. The least expensive option seems to be boxes like those in the links below. Does anyone have any experience with these things ? Do they work well ? Any other suggestions ?
http://sewelldirect.com/Component-YPbPr-RGB-RCA-to-Composite-Yellow-RCA-and-S-Video-Converter-w-Down-Scaler_reviews.asp
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=7114&seq=1&format=2
Thanks for any replies.
post #8 of 9 Old 10-08-2012, 04:33 PM
CitiBear's Avatar
Quoted: 115 Post(s)
Liked: 97
I sorta thought you already understood that component>s-video converters were active boxes, and not simple inexpensive cables, so I didn't post anything further after you solved the composite input issue. Your last post didn't seem to pose additional questions that needed a quick answer: it appeared you knew how converters work and were just telling us you might want to try one in future.
Regarding these converters, they come in roughly two quality/price categories: about $50 and adequate, or about $300 and excellent. The converters that sell for less than $100 generally have compromised PQ with issues ranging from softness/muddiness to incorrect IRE level (making dark areas of the video blend together and lose details). The expensive converters give a much clearer signal, but they are pricey. Unlike some other electronics where you can get away fairly cheaply, with converters you do unfortunately "get what you pay for" (more $$$ = better quality).
The $50 converters are usable if you aren't too picky, and willing to accepted compromised PQ in exchange for a full 16:9 signal to your recorder. I've been experimenting quite a bit with the MonoPrice component converter, as well as a similar unit that converts HDMI to S-Video. On the whole, I think I get better video quality recording the standard 4:3 letterbox output of my cable box and zooming it with my TV (the color is better from letterbox, and any detail advantage of "true" 16:9 is killed by the muddiness of the conversion). I now limit my converter use to occasions when I forget to record a TV series episode from my off-air antenna in 16:9, and need to get it from cable on-demand. Using the converter keeps the entire set of episodes matched in 16:9, and current TV series are "punchy" enough to survive a cheap converter. I would avoid using the cheap converter for a movie or other spectacle where the cinematography is important: you'll get cleaner results zooming into the letterbox 4:3 output of your decoder box.
Note some of the first-generation DVD recorders actually did have component inputs, and were capable of internal conversion to pass thru their composite and S-Video output jacks. Using one of these older recorders as a "converter" nets PQ somewhere between the cheap $50 converters and the excellent $300 converters. The drawback is you need to find such a recorder, they take up a lot of space, and draw more power (because you'd be leaving it on all the time). The most common and inexpensive recorder with component conversion feature was the Philips DVDR72, circa 2004. These pop up for approx $50-$70 on Craigs List and eBay. The recorder doesn't have to be fully functional, it just needs to power up (you won't be using its DVD drive, which is most likely broken anyway).
CitiBear is offline
post #9 of 9 Old 10-08-2012, 06:29 PM
kjbawc's Avatar
There is a whole, long thread about converters:
http://www.avsforum.com/t/828063/cheaper-component-to-s-video-converter
I have two Monoprice Lenkeng converters, an Audio Authority converter, and an Atlona converter. The Monoprice converters cost about $40. The other two list at about $300. The more expensive ones usually provide a sharper picture, but have problems of their own. They make darkened scenes too dark. They have problems locking on to SD signals that are letterboxed. Also, both of my expensive ones have an occasional quirk where there is a horizontal interface line that seems to be caused by the lower half of the frame being delayed, so that it doesn't quite match the top half of the frame, especially when there is horizontal movement in the scene. When recording from an SD source, I prefer to use S-Video, direct from the source, usually one of my DVRs. I only use a converter when I want to make an anamorphic DVD from a HD source.
kjbawc is offline
