For Healthy DVDs; One Banana! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-12-2012, 10:15 AM - Thread Starter
Quoted: 38 Post(s)
Liked: 198
7558037 is offline
post #2 of 2 Old 10-12-2012, 01:09 PM
VoxHumana's Avatar
I find that scratches are not much of a problem. The problem is grease or skin oils.
Here is what I do:
1-Wash my hands with liquid dishwashing soap.
2-Rinse the recording side of the DVD with luke-warm water.
3-Put a drop of liquid dishwashing soap on the DVD's recording side.
4-With my fingers I spread the soap from the center hole to the edge and give the DVD a gentle massage.
5-Rinse off the soap with luke-warm water.
6-Gently dry the DVD with a soft towel or cloth.
DVD CLEANING, 1.JPG 296k .JPG file DVD CLEANING, 2.JPG 278k .JPG file DVD CLEANING, 3.JPG 471k .JPG file
Name:	DVD CLEANING, 1.JPG
ID:	64312   Click image for larger version
Name:	DVD CLEANING, 2.JPG
ID:	64313   Click image for larger version
Name:	DVD CLEANING, 3.JPG
VoxHumana is offline
