More Duo 222k Questions...Hey Wajo! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-20-2012, 10:53 AM - Thread Starter
KingB84's Avatar
I'll try to keep this understandable.
1) My receiver keeps powering down in the middle of the night
2) I can't find a code for my VCR portion of my DVD Recorder/VCR combo (strange)
3) I've been trying to set up for ERD with no success
4) I can do all the recording I want manually, it's just timer-recording that's bothering me
5) I have the updates mode disabled and still #1 continues each night
6) I have been using the autotune timer type. Even if the receiver is off, it's supposed to turn on for selected programs. Doesn't happen. If I select "VCR" timer and set begin and end times would that affect the receiver. I don't see how, since it's not setup to run the DVD/VCR combo (ERD)
Thanks for ideas and help.
KingB84 is offline
post #2 of 3 Old 10-20-2012, 10:59 AM
Guest
Quoted: 38 Post(s)
Liked: 198
I don't use a cable or sat STB/receiver so can't help from personal experience on this.
For others, here's the original set of posts on this subject to get you "up to speed."
7558037 is offline
post #3 of 3 Old 10-20-2012, 11:36 AM - Thread Starter
KingB84's Avatar
That was me on a different topic. No help there. Thanks anyway.
KingB84 is offline
